timing cover
Old May 10, 2007 | 06:08 PM
ssls6's Avatar
ssls6
Default timing cover
My wife bought me a "live to ride" timing cover for my 98 FLHR. Do I simply drill the heads off the old rivets and go back with rivets or what? Do you need to fish out the old rivet bodies after drilling the head off?
Old May 10, 2007 | 07:06 PM
rick867's Avatar
rick867
Default RE: timing cover
did it to my sons 97 ultra,drill out rivits,be careful new cover should bolt right up,if not then chase thred with tap
Old May 10, 2007 | 07:19 PM
zukeeper's Avatar
zukeeper
its a blind rivot , once you take off the cover you'll see another cover that is screwed on. just remove the leftover rivot parts and depending on how you need to locate your cover so up is up , either get screws a bit longer and run them through your new cover , the backing cover and into the adjustment posts if you need the holes to be on the sides or, go to a stealer and get a couple of new blind rivots if you need to have the holes top and bottom and put things back like it was
Old May 10, 2007 | 09:02 PM
im's Avatar
im
good stuff above...the hd part number for the special rivets are HD-8699 if you need them , about $1 each..you can use a regular rivet gun..these rivets are sealed on the end so nothing falls into the cone...
Old May 11, 2007 | 09:55 AM
ssls6's Avatar
ssls6
Thanks for all the great replys.
larsfum
EVO
Oct 27, 2015 09:06 PM
Kojax
Nov 18, 2012 07:34 AM
pat112
Aug 2, 2008 09:38 PM
patter850
Jul 28, 2008 01:47 AM
kiddoc
Mar 24, 2007 12:30 PM
