CB750 nighthawk Cafe
Old Jul 18, 2012 | 11:28 AM
JRK5892's Avatar
JRK5892
Default CB750 nighthawk Cafe
Hello! figured it was a good time to show the bike we are building in the shop here... we got a good deal on a nighthawk 750 so we added that to our build sheet of bikes we are working on in the shop.
here is where we are so far.
on the lift
trying to figure out what direction to go
we decided to go with a vintage cafe set up that i have been stashing for a CB750 just always pictured it on a vintage one! hahaha so now to make it work... first back of the frame was removed to drop the seat low
then we had to get the tank lower... so sectioned out part of the back bone... this will all be re welded and supported with 3/8" plate so it is just as strong if not stronger than the original set up... will basicly turn it into a slugged I beam
tank sits lower
then she lost some weight
what we will use from the stock pipe
came across this for inspiration on the build
shot some sample bottles of colors we think we may go with
then some more mods to get the tank as far forward and get the smooth line that this bike needs to hold the vintage look on a newer bike
Old Jul 18, 2012 | 11:30 AM
JRK5892's Avatar
JRK5892
more weight loss
so we got some more done last night on the scoot... decided we are going to shave the front of the seat 1 inch, recut and shaved the foam to round it off a bit, then re cover the seat... run an under tail exhaust, got our build plan finalized, and mocked up the rear set location so the mounts can be welded into the frame... also started the back bone support
spot welded into the frame front and rear... went about 3 inches into the front angle support and little less with the rear but still pretty deep into it
the brace was made very long so that it could tie into the factory bracing
once the motor is pulled more welds will come from the under side... and the plate will be final welded in all the way around
then worked on our rear set location... temp just drilled them in to see where we wanted them...
Old Aug 12, 2012 | 10:35 PM
m i k e's Avatar
m i k e
shaweet lookin forward to those colors
pimpin
TLoud
Apr 16, 2020 08:30 PM
jackietan
Jul 17, 2016 03:09 AM
guitarman023
Apr 13, 2016 11:45 PM
Steen
Feb 28, 2014 05:16 AM
JRK5892
Custom Models
42
May 3, 2010 03:53 PM
