open primary
Old Aug 5, 2005 | 08:48 PM
crazyhorse's Avatar
crazyhorse
Stage III
Default open primary
I have this small leak on my custom chopp. I have this BDL open primary and it seems to leak on the engine side. The seal behind the stater. I had the bike in the shop several times and they cannot seem to gix it. Can you help a brother out? Thank you
Old Aug 5, 2005 | 09:42 PM
pococj's Avatar
pococj
Default RE: open primary
What has the shop done in trying to fix it?
Old Aug 8, 2005 | 10:07 PM
crazyhorse's Avatar
crazyhorse
Stage III
the shop just replaced the seal and torqued the nut to specs. Maybe they are pulling my chain and it sucks.
Old Aug 9, 2005 | 01:26 AM
pococj's Avatar
pococj
ORIGINAL: crazyhorse
If it leaks after the seal is replaced it is due to seal damage, or possible damage to the shaft and/or cavity the seal goes in. Have seen the seal installed backwards, too.
Old Aug 9, 2005 | 06:25 PM
12Stones's Avatar
12Stones
Let us know how it turns out.
Old Sep 4, 2005 | 02:44 PM
jnash's Avatar
jnash
Stage III
.....there are usually two screw holes that are used to hold a clamp for the stater wires in place, if they are missing and are drilled clean through into your crank......then there's your leak, this is what happend on my electra glide sport... or your seal housing may be cracked. Good luck!
customsoftail200
Jul 23, 2025 09:11 AM
rocky5
General Topics/Tech Tips
19
Jan 7, 2015 06:26 PM
motox285
Jul 1, 2010 10:24 PM
eohdtech
Jul 29, 2009 09:51 AM
Canuck HD
Jun 13, 2007 07:35 PM
