revtech backfire issue
Old Oct 7, 2012 | 07:23 PM
mxrider101's Avatar
mxrider101
6th Gear
Wink revtech backfire issue
Working on a friends bike so I have minimal info. J know its a revtech with mikuni carb. Cleaned carb and it looks great now. Problem is it runs and idles great, but when trying to accelerate it backfires badly and will die. No idea how long it has sat, if it ran good prior to this problem, etc. (Waiting for a text back still) I am thinking bad fuel or timing. Any suggestions where I should go from here? Thanks for the great forum and people on it!
Old Oct 8, 2012 | 12:54 AM
mxrider101's Avatar
mxrider101
6th Gear
Found out bike has been sitting close to 6 years! Its amazing it runs at all! I will change fuel tomorrow after work and see what happens.
Old Oct 11, 2012 | 12:03 PM
JRK5892's Avatar
JRK5892
change fuel and then check the ignition... rev tech are known to burn though ignitions... on the last one we did we had to machine out the ignition cover and put a screen there, so that it would get some air... also highly recommend compression releases or you are going to go though starters and/or batteries like mad
they pull apart pretty easy
Old Oct 11, 2012 | 12:31 PM
mxrider101's Avatar
mxrider101
6th Gear
Thank you! I changed fuel but same issue. I took right cover off. The electronic ignition is set at 0 on left dial, 5 on right, but I have no idea what should be! I am near positive it is ignition, just not sure where to begin of how to test it!
Old Oct 12, 2012 | 11:58 AM
JustDave71's Avatar
JustDave71
You're working on someone's bike but don't know how to troubleshoot? Not tryin to be a dick.
When you cleaned the carb, were you careful not to clog any passages? Did you set it up correctly? Is the accelerator pump working properly? Is the carb as a whole?
Definitely flush that gas, clean the fuel filter (s)...me personally I'd run some Marvel too.
what about air leaks or vacuum leaks?
Old Oct 12, 2012 | 01:24 PM
mxrider101's Avatar
mxrider101
6th Gear
Of course I was very meticulous with the carb, cleaning tank, checked for leaks, went through wiring checking for loose wires, etc. Just not familiar with revtech ignition.
Old Oct 12, 2012 | 07:29 PM
JustDave71's Avatar
JustDave71
Not sure how "of course" comes into play here. Most people are nowhere near meticulous. Not a judgement just an observation.
The problem you're describing seems to be a fuel delivery issue...carb's at the center of that, of course. But yeah, seems like gas, BUT...I had a bro who had a DTT nosecone module in his SPCN fxr-style bike...started gettin misfires here and there. Idled fine, revved fine no load, but when he'd get on it under load, actually riding, it'd start spittin flames bang bam boom! Nosecone module was overheating and going haywire and it would only show up under those specific conditions. He also had the timing all f-ed up cuz he thinks only dorks read manuals so he just "does it by feel." So yeah maybe timing.
Pretty sure RevTech ignition setups are based on the Crane Hi-4 which was notorious for being finicky AND overheating.
Have you considered the VOES if it's running one? Weird **** happens when they go froggy.
Old Oct 12, 2012 | 09:50 PM
mxrider101's Avatar
mxrider101
6th Gear
Of course as in anyone who works on carbs should be meticulous. I have dealt with a lot of fuel issues and this don't act like any before, so I suspect ignition. On that note I will definitely be going back thru the carb and fuel system just to be sure. Any suggestions if you believe it may be jet size issue? Up or down on size? It appears to be 100 ci running down sweep pipes. No baffles. Have had very little time to work on it so was kinda doing my trouble shooting from here. Thanks for the responses!
Old Oct 13, 2012 | 11:04 PM
ZZZCICI's Avatar
ZZZCICI
Obviously, start with the most simple stuff first. ensure high voltage spark at both plugs, check condition of ignition wires and ignition timing . If all that checks out I would consider the valve timing, burnt, bent, or damaged valves. Then condition and propre operation of cams, cam chain, or gear drive. Trouble shooting is basically the process of elimination. Do you know what happens when plug wires are crossed up?
Old Oct 13, 2012 | 11:55 PM
mxrider101's Avatar
mxrider101
6th Gear
Definately great ideas by all. I think fuel has been eliminated as the issue. I will head to ignition next and see what I can find! Thank you all'
