Building a Paughco custom
Old Mar 21, 2013 | 08:24 AM
NativeTexican's Avatar
NativeTexican
Default Building a Paughco custom
I have been thinking about building/rebuilding a bobber for several months. But I can’t really find a good cheap donor bike. While searching the interwebs I came across the Paughco website. They seem to have almost everything needed to build a bike. I was wondering whom has done this and what was your experience working with Paughco.
Old Mar 21, 2013 | 07:54 PM
misfitJason's Avatar
misfitJason
Well thousands of people have done it with a paughco frame as have I a few times. The company has been around since the seventies and are one of the largest frame manufacturers. They also own several smaller companies as well.
The frames are good quality and they have a huge number of options for whatever you want to build. They will also make you a custom frame but you will have wait time.
Go for it. The only recommendation I will give you is to take your height into consideration. If you go crazy stretch and are 5-8 you might have some problems.
I can build a bike cheaper without a donor bike but I know exactly what's fits whati and what I am going to use at this point so it cuts down on costs not having to buy the same parts over again because the don't fit
Good luck and feel free to pm me with questions
Old Mar 21, 2013 | 09:50 PM
Mntmatty's Avatar
Mntmatty
i love my 07 paugho! used a donor 2000 1200 sporty. I am happy i had the donor bike but agree that now that i know what to expect I wouldnt need it
Old Mar 22, 2013 | 07:13 AM
NativeTexican
Thanks for the feedback.
I am going to keep it simple with the frame with a single down tube, springer frontend and one of their motors.
Old Mar 22, 2013 | 09:51 AM
Mr.Barnes's Avatar
Mr.Barnes
Make sure the springer you run is wide enough for a front disc brake setup if you intend on having a front brake. I love my narrow springer but if I could go back in time I would make sure to order a springer that would work with a front disc. Those mini drums wont even hold me at a stop on a hill. Nothing like dancing a jig to pull away on a hill, im glad I decided against a jockey shift.
Old Mar 22, 2013 | 10:57 AM
misfitJason
I agree with the above. A light and simple bike is fun but I am over my younger days when I thought drum brakes were cool. Brakes brakes more brakes. I have been using a two piston will wood in the rear and a stock softail one up front and they work quite well
Here is a pic of my paughco
Old Mar 23, 2013 | 09:12 AM
TwiZted Biker's Avatar
TwiZted Biker
Funny you should mention brakes This is what happens when you have lots of spare stuff laying around and your bored . I did it just because I could and actually worked out like ABS for me I have to stand on pedal to lock them but it'll haul it down fast
I just snagged a deal on a set of 4 piston Wilwoods I'm going to set them on the 60MM inverted frontend I'm running , the stock calipers are ok but .............
OP I've built over a dozen bikes using Paucgho frames from hardtails to stretched swingarmed bike and they are solid and most times thing fit fairly well for the price ( can't beat it ) but think about making your own heavier add on brackets like the upper motor mount tabs sometimes they used rather thin stamped sheet metal but it's no big deal if your already in that deep . Other thing I'll suggest do a careful fit up of all the bolt on goodies like the tranny plate , forward controls , and the tabs for oil tanks and such found some stuff to off a bit and had to moved or tweaked a bit for the best fit . I have had a frame come in with the neck 3 deg off so once so I do suggest you set it up and do a alignment check on everything before you start in . Real easy to do with a string line and a length of pipe or rod . PM me if want particulars .
Old Mar 23, 2013 | 04:35 PM
misfitJason
now that's some brakes
Old Mar 25, 2013 | 07:38 AM
NativeTexican
That sound stop a bike for sure.
Old Mar 20, 2014 | 12:11 PM
sickchops's Avatar
sickchops
Stage II
TwiZted Biker could you please message me about the checking of alignment of the paughco frames. I am thinking of getting one and want to know more about how to check one as i have no frame jig to do so. Thanks
SLO_ROLL
Custom Models
Jun 19, 2012 10:04 PM
ewhip17
Custom Models
Jul 15, 2011 09:01 PM
kimruger
Sep 12, 2010 10:09 AM
Rocket Jockey
Custom Models
Apr 2, 2008 09:26 PM
DirtyWhiteBoy
Jan 12, 2007 11:40 AM
