Biggest Battery?
Old Mar 10, 2007 | 05:36 PM
Night_Train01's Avatar
Night_Train01
Default Biggest Battery?
Does anyone know who makes a battery with more than 375 CA?
I put a Revtech 110" motor in my Dyna project bike complete with a four speed trans, the largest starter that will fit the four speed is a 1.4KW. The battery I have does not have the umph to start the bike......I had to install the kicker just so I can get the bike off the compression stroke so it will fire...I installed the high torque Spyke starter but it did not help. If my battery (which is new)is not completely charged there is no chance of the bike turning over. I have been looking around for a stronger battery but have no luck finding one....I figure there must be somebody building a stronger battery.
Old Mar 10, 2007 | 06:38 PM
dog155's Avatar
dog155
Default RE: Biggest Battery?
375CCA should be enough to start your 110". Check your batt cable size and especially the grounds.Iv'e had zero problems with my 124" using 375CCA bat and stock Harley starter.I did install very heavy fine strand cables # 2,and keep a battery tender hooked up all the time.Also have compression releases.
Old Mar 10, 2007 | 08:49 PM
Night_Train01
Well, thats the main problem......the Revtech motors do not have compression release valves. I could put some in but that would void my 30K warranty. I would think that most people would use these motors with a 5 speed trans and a 2.4KW starter, then there would not be a problem. I leave a battery tender on all the time but the battery still needs a little more juice to crank the motor.
[IMG]local://upfiles/6165/C7511E69CDCE4F75A5E168E2CDCA06FD.jpg[/IMG]
Old Mar 11, 2007 | 11:51 AM
dog155's Avatar
dog155
I would check with Rev Tech to see what they might have to say.My guess without being there is the motor might be a little tight,or the timing curve is a little aggresive.There are still more options to help start a big inch motor.Starter ring and pinion, 64/10 I believe is the combo,for a start.Hang in there!
Old Mar 11, 2007 | 09:52 PM
Night_Train01
What I have discovered is that if I remove the plugs and crank the motor over a few times and then put the plugs back in the motor then spins freely and the motor fires right up. If you then shut it off, it will not start again until you remove the plugs, spin the motor and then put the plugs back in.....I hate to have to carry a spark plug tool everywhere I go.
I have contacted the tech service at CustomChrome (they are the dealer for RevTech) each time I talk with them they say to adjust the plug gap.....I explained that its not a matter of the motor not starting when it does spin, its a matter of the motor not turning over at all.
Its almost like the motor locks up, stuck in the compression stroke.....and will not start until you release that compression.
Old Mar 12, 2007 | 10:08 AM
dog155's Avatar
dog155
With out a few tools and actually standing by your machine it is hard to diagnose the problem.You must have very good compression,and I wonder what kind of ampheres you are drawing when trying to start the motor.Those 110"'s were built to start without comp releases,yours should start too.Maybe your starter is dragging.Without doing a couple of tests it is impossible to say what is going on.Call Rev-Tech directly,if you can or have some tests done on your starting system.You have to start eliminating some questions.Good Luck
Old Mar 12, 2007 | 04:43 PM
Bigdave 789's Avatar
Bigdave 789
Hi. Got just the battery for you. The Odyssey Battery model PC535 if you have a wet battery type YB16-B usually found on pre 97 models or PC545 on later and current models. The Pre 99 FLH can take the PC680MJ and post 99 to present can take the PC925LMJ. Odyssey are manufactured in the USA to a military spec, they are totally sealed and will not leak, they use pure lead technology and give 3 times the cranking power for an equivalent sized conventional battery. I know because I am the UK distributor and the PC535 will start a Rev Tech 1700 motor with no decompressor valves with ease. Saw it do it with my own eyes. have a look on my website www.knightbatteries.com I've got a PC545 on my 35th Ann Superglide, starts first throw every time.
Old Mar 17, 2007 | 11:23 AM
Night_Train01
I bought an Odyssey battery PC535 this week....I will install it on the weekend, if it starts this motor I will be very impressed. I will post later with the results
Old Mar 21, 2007 | 03:15 AM
hograzer's Avatar
hograzer
6th Gear
I have a Rev-Tech 4x4 100
I would check if your VOES switch is working right
also leave throttle shut when starting
It may have to do with the number of teeth on your starter and clutch
i havea new Yuasa YTX20HL with 310 cold cranking amps[/align]i wonder that bigger batery will fit my bike[/align]i have the 9 tooth 84 tooth arrangement
Mine starts hard, but starts
i also can turn off the headlight while starting
[/align]
Old Mar 22, 2007 | 06:19 PM
Night_Train01
I installed an Odyssey 535 battery on the weekend.......my starting problems are gone......this battery spins the 110" with no problem at all.
