Biggest Battery?
Old Mar 23, 2007 | 09:56 AM
dog155's Avatar
dog155
Default RE: Biggest Battery?
What are the CCA of this battery?
Old Mar 23, 2007 | 04:02 PM
Bigdave 789's Avatar
Bigdave 789
The Odyssey PC535 will produce 535Amps for 5 seconds which is all you will ever need to start your engine. Try counting out 5 seconds and imagine cranking your engine on the starter in all that time. No other lead acid motorcycle battery of a similar size comes even close to an Odyssey for starting power.
Old Mar 23, 2007 | 04:17 PM
shooter64's Avatar
shooter64
Former Sponsor
Curious...how does compression releases void your warranty...when they are drilled on the pushrod side of the motor for compression releases. I have sold quite a few motors, and maybe I overlooked it, but had no one ever tell me that, or did I ever read that they would void your warranty. They help you motor start easier, how can that void your warranty. If warranty is the issuse and you have a problem, just take the releases out and put the plugs back in before you take it to the shop.
Old Mar 23, 2007 | 08:20 PM
Night_Train01's Avatar
Night_Train01
The new RevTech 110" do not have the extra hole on the push rod side of the motor....the heads would have to come off to drill out the new location for the releases. I totally agree, they make starting the motor very easy.....somebody at Revtech was asleep when the company talked about compression releases.
Old Mar 23, 2007 | 11:24 PM
shooter64's Avatar
shooter64
Former Sponsor
How about the Spike compression releases, we have use a few, the ones that are built in with the spark plugs, you gotta pay attention when putting them in, but they work well, we have done probably three sets. You have to use a different longer plug, think its a plug that goes in the ford triton motor, but they work really well.
Old Mar 25, 2007 | 10:37 PM
dog155's Avatar
dog155
535 cca? that ought to be enough to start most engines.
Old Aug 10, 2007 | 05:21 AM
brad75raiders's Avatar
brad75raiders
how much was the battery?
brad75raiders
how much?
RonS0921
Oct 5, 2022 01:48 PM
Scooter Pieman
Jan 12, 2018 05:21 PM
Whiskyjock
Nov 15, 2017 10:24 AM
maryvillept
Feb 5, 2015 07:44 PM
djprey
Jun 26, 2007 12:36 PM
