97 Road King Issues
This is actually my second post here as my First was the introduction.
I have searched my issue that I am having but am curious on the situation.
We bought our bike a week ago from a dealer and we had it running fine last weekend. The dealer didn't tell us about buying a battery tender but told us the battery already had the wires hooked up to the battery for the tender.
I went out Thursday night to try and start the bike as we had real frigid temperatures the days before and the battery had really weakened and not strong enough to start the bike. So I did a search about jumping the battery from a vehicle on Google and it brought me here which there was some posts about doing that and others succeeded doing this. So today I went and hooked up the cables to the bike and my 99 Durango (did not start Durango). Let it sit for a while charging and it finally cranked over. I let it sit and idle for almost an hour once in awhile revving the engine alittle. I put the bike back into the garage and shut it off. I tried to restart the bike and all I got was a load constant clicking noise, I guess from the starter. I am guessing from other posts I have read about the clicking noise is the battery is shot. Is there a way I can tell or test to see if I may have damaged anything else while doing the jump start procedure?
Thanks much in advance for your help and assistance in this matter.
2.) a battery once discharged will only recharge to about 50% of it's rated capacity..meaning that once it is run down you are living on the edge of failure...that failure can leave you stranded- or as above take out the charging system.
3.) air cooled motors are cooled by air moving across the motor externally and the oil moving through the inside. DO NOT idle your motor for long periods
4.) the loud clicking is your solenoid chattering...allowing the solenoid to do this can damage the solenoid- the contacts can arc as can the disk. once damaged then it needs rebuild or replacement
5.) if you hold down the starter button and the starter doesn't turn over, but you hear a whine ( or worse smoke from the starter) that is the windings in the starter motor burning up...$$$
all this points to:
get your battery load tested at auto zone AFTER putting it on a real battery charger at a rate of 5 to 10 amps for at least 24 hours.
if it is duff, check online for a deka battery dealer and get a price on a deka AGM battery
while at it, replace both battery cables with new- you can get cables of suitable type at autozone-
and buy a battery tender which will help maintain the battery once it is fully charged.
If you are not going to use your bike until spring- keep the battery inside ( room temp) and on the tender.
try to resist the temptation to go out and start the bike during the winter- this is not at all good for the motor- a cold start has the metal parts moving without a ready supply on oil, the piston rings are not well seated to the cylinders and gas and exhaust will leak down and corrupt the oil.
on start up, the evo may blow out the cylinder base gaskets if you hammer it when cold.
best practice is to start and warm the motor until the heads are warm to the touch-- then take it easy for the first 5 miles or so
Mike
Mike, thanks for the info those are some scary thoughts there, but makes a ton of sense. Thanks for sharing that info.
all this points to:
Mike
Also, Not sure where I can find this info out, but is there a place I can search for what size Torx drives I need for this bike? Seems alot of the bolts are the Torx drives and I don't have any right now and would like to get them while I can.
These are the ones I carry on the bike, and use more often than any...
http://www.harborfreight.com/9-piece...set-67914.html
