Primary/tranny options
Old Apr 3, 2014 | 01:32 PM
daxcobra's Avatar
daxcobra
Default Primary/tranny options
Hi guys, dave in uk, need a bit of a steer, currently getting parts together for a custom build later in the year, will probably be using a rigid ultima frame or similar. I have a set of crankcases which I believe are from a 2006 flhtci, crank will arrive next week, going to go with a cylinder kit 97 inch, and put together a strong, reliable motor, question is what primary/tranny options will I have using this set up in a custom frame? Parts difficult to come by over here so need to work out the best options. Thanks. Dave
Old Apr 9, 2014 | 07:15 PM
misfitJason's Avatar
misfitJason
vulcan works makes adapters for the motor to an evo frame and for the twincam motor to run an evo primary. The quick answer is you would have to run a 93 to 99 evo primary setup
Old Apr 11, 2014 | 03:42 PM
corliss@bakerdrivetrain.com's Avatar
What do you need? If I don't have it I'll get it?
Old Apr 12, 2014 | 06:51 AM
Tom84FXST's Avatar
Tom84FXST
http://vulcanworks.net/store_4/produ...roductid=17184
20"ape
Oct 17, 2014 01:43 PM
hdpeanut1
Mar 17, 2011 10:28 PM
mhuff
Dec 31, 2010 06:40 AM
mhuff
Dec 30, 2010 01:04 PM
PowerSmoke
Dec 12, 2010 01:34 PM
