condensation
Old Mar 19, 2017 | 04:13 AM
harleyHBX's Avatar
harleyHBX
Stage III
Default condensation
does anyone know how to remove condensation from inside the speedo glass?
Old Mar 19, 2017 | 10:27 AM
Johnnyh14's Avatar
Johnnyh14
Sit your bike in the sun.
Old Mar 19, 2017 | 10:29 AM
Uncle Larry's Avatar
Uncle Larry
Yep ... Johnny is right. There are several threads here about condensation. How to remove and reseal the glass. Waaay more trouble than it's worth.
Old Mar 19, 2017 | 11:47 AM
checkers's Avatar
checkers
You will need access to a large solar generator for approx 59 minutes. It is best performed on a dry day above 70 degrees. Results may vary and reapplication may be needed.
Old Mar 19, 2017 | 02:01 PM
Campy Roadie's Avatar
Campy Roadie
They all do that.
Old Mar 19, 2017 | 02:09 PM
Jackie Paper's Avatar
Jackie Paper
Mine does not do it but I hang it with the bicycles during the winter.
Old Apr 28, 2017 | 05:14 PM
bambambam's Avatar
bambambam
try using a hair dryer or if your careful a heat gun
Old May 4, 2017 | 10:07 AM
oldtoad's Avatar
oldtoad
Being that the speedometers are sealed the moisture never leaves. Differences in temperature will make the moisture either evaporate where it can't be seen, or form a liquid on the glass that annoys everyone. Once the liquid evaporates, it becomes invisible as a vapor, but always returns since it is a sealed unit and can't really escape. I think the problem could be taken care of during manufacturing if done correctly in a low to no humidity environment.
Old Jun 21, 2018 | 09:38 AM
cmhdwg09's Avatar
cmhdwg09
It would seem that if it is sealed so poorly that moisture can enter, then moisture can leave. Seems like over time, it should clear up.
Old Jun 21, 2018 | 09:41 AM
Uncle Larry
https://www.google.com/search?q=remo...w=1525&bih=739
Skeezmachine
Aug 6, 2018 02:35 PM
Purple-RT
Jan 29, 2017 09:04 PM
elderberry99
Sep 4, 2012 06:19 PM
texfatboy
Apr 20, 2008 07:05 PM
Tommy Meisel
Sep 11, 2007 02:59 PM
