Eagle, I lied, I did use "Paint Guard +" Since there is nothing on the paint, and riding season is winding down, Would you recommend a couple coats?
I ask this cause today it is 70 degrees and low humidity and I have it and want to protect the paint before the cold weather settles in.
UPGP is a really good and easy to use sealant. It won't hurt anything to apply it now. I do 3 coats however, if you plan on applying something else this winter 2 will be fine.
If/when you decide to apply something else, you will need to make sure the paint is free from any LSP, basically you will need to polish.
