Ceramic coating and bug removal
Old Mar 14, 2024 | 08:36 PM
steelpony16's Avatar
steelpony16
Default Ceramic coating and bug removal
Just had my bike polished and ceramic coated. What's the best way to get bugs off without degrading the ceramic coating? On previous bikes without ceramic coating I've always used peroxide/water mix and meguiars bug and tar.
Old Mar 15, 2024 | 04:39 AM
TracerBullet's Avatar
TracerBullet
I use a warm wet towel and let it sit for a bit on any area that is really buggy. Other wise just water and a light detergent. I use S2000.
no matter what you do the ceramic will degrade over time.
Old Mar 15, 2024 | 05:25 AM
HD_noobie's Avatar
HD_noobie
https://mckees37.com/products/road-k...41252708319395
This stuff works great and can be used as a bike wash when diluted with water.
Old Mar 15, 2024 | 06:39 AM
steelpony16
Thanks.
There is plenty info I found while searching this morning, couldn't find it last night with my phone.
TGIF!
Old Mar 15, 2024 | 08:22 AM
CaffeineBuzz's Avatar
CaffeineBuzz
I get em right away....bug guts are often fairly acidic, and the longer they sit, the more they grab onto the surface...bug guts will etch and damage a clear coat
i avoid bug removers....they are harsh chemicals meant to dissolve organic compounds....I wouldn't use it unless i also planned on washing the bike afterwards
avoid scrubbing bugs off the surface.....contaminants should lift with one pass of a microfiber....let washes dwell a bit...but don't rub an MF back and forth until you scrape the the bugs off
most of your damage to your coating and your clear coat will occur because of washing the bike, even if you do it properly, there is no way to avoid the damage you are doing...so don't be obsessed with keeping it perfect....it stopped being perfect about 20 minutes after it was done
Old Mar 15, 2024 | 08:51 AM
jwt873's Avatar
jwt873
I do the wet towel thing too.. Soak it so it's dripping wet and lay it over the windshield/fairing. It should cling to the surface. Leave it for about 1/2 hour and the bugs will soften to the point they're easy to remove.
Old Mar 15, 2024 | 11:19 AM
eaglefan1's Avatar
eaglefan1
Pre soak with foam or a waterless wash and give it a few minutes. Depending on the coating it should come right off extremely easy.
How much soak time depends on how long the bugs have been on the paint. When it's bug season here I make sure to get them off all of our vehicles that day. Takes maybe 10 min total.
Old Mar 15, 2024 | 12:13 PM
Bayou FLHR-M8-128"'s Avatar
Bayou FLHR-M8-128"
As one just stated, absolutely use waterless car wash products as they work very well and are not harmful on ceramic coatings. Would be best to spray it down and let it soak for about 30 seconds to soften the debri.
I also always use compressed air (rubber tip advised) to blow off as much as I can prior to uisng waterless wash, and preference is the RainEx brand.
The more you use the RainEx waterless the better it gets, to where hardly anything sticks to surfaces.
Old Mar 15, 2024 | 02:03 PM
eaglefan1's Avatar
eaglefan1
So Rainex is leaving some protection behind?
If you like Rain x keep using it. There is much much better out there in my opinion. Definitely cheaper and more versatile.
Old Mar 16, 2024 | 03:21 AM
tpb857's Avatar
tpb857
I'm interested in what you would recommend. Thanks.
