Reflecter removal
Old Nov 30, 2005 | 09:59 AM
MuddyXL's Avatar
MuddyXL
Default Reflecter removal
How do I remove those budugly reflectors from the fork lowers and fender sides and hopefully liberate the nice finish underneath?
Old Nov 30, 2005 | 10:07 AM
Bujin's Avatar
Bujin
Default RE: Reflecter removal
personally I use a heat gun to heat up the double stick tape and using a putty knife and towel pull it loose. Then take some glue remover (one that won't damage the paint) and clean the residue off. After that if need be I rewax the area and buff it out. Be careful when heating the reflector, it gets hot and will burn. Don't hold the heat gun in one spot too long, this may damage the paint on your fender. Also be careful prying with a putty knife that you don't slip and scratch anything. I use the knife because the reflector is too hot to touch. Gloves would probably work well too. Good Luck
Old Mar 11, 2006 | 12:26 AM
redhot's Avatar
redhot
Take some heavy duty fishing line,about 2 feet, tie each end to some type of handle. pull the fishing line down between the reflector and the frame or what ever you are taking it off of working it back and forth. Then get your GOO GONE and remove the glue. Using the fishing line you will not mar the frame.
Old Mar 15, 2006 | 06:12 PM
93 fatboy's Avatar
93 fatboy
A citrus solvent will remove adhesive
Old Mar 15, 2006 | 08:20 PM
whodat?'s Avatar
whodat?
6th Gear
3M makes an adhesive remover too. Don't know if that would help any.
Old Mar 15, 2006 | 08:30 PM
scttgr8's Avatar
scttgr8
redhott has the easiest way...thats the way ive done it for years. also works for body trim on the cage ... anything stuck with doublesided tape.
Old Apr 10, 2006 | 08:46 PM
Tourer's Avatar
6th Gear
Hair dryer and then dental floss. Use vegtable oil or Goo Gone for the residual adhesive.
Old Jun 1, 2006 | 08:01 PM
springster's Avatar
springster
3rd Gear
WD 40 works great
Old Jun 1, 2006 | 09:02 PM
Primo's Avatar
Primo
ORIGINAL: redhot
This is what I do. Just that I add a little WD-40 to the fishing line for an extra lubrication barrier against the paint.
Old Jul 5, 2006 | 01:29 AM
misfit's Avatar
misfit
sticker shock worked well for me.
