simple green
Old Jun 10, 2009 | 08:41 AM
utz's Avatar
utz
Default simple green
is it ok to spray simple green all over the bike paint and chrome then rinse it off someone told me this is all they use does it leave any spots on the bike when it dries
Old Jun 10, 2009 | 09:49 AM
RCB's Avatar
RCB
I believe that Simple Green is basically a cleaner/degreaser and that when applied will remove any wax/protection to your paint and chrome. Which would mean you will need to wax paint and apply wax or chrome cleaner/polish after using SG. Personally I would not use it on painted surfaces.
Old Jun 10, 2009 | 10:37 AM
Lakerat's Avatar
Lakerat
If you have any polished aluminum, there is the possibility of etching.
Old Jun 10, 2009 | 08:51 PM
Bikerdad61's Avatar
Bikerdad61
+1 on this. Simple green even though it's biodegradable is still considered a degreaser. If you want an all over spray cleaner try a can of
S100 Total cycle cleaner. It's a spray on out of the can, let sit for a few minutes and hose off. You can spray the entire bike with it.I've used it several times. good product. Available at most all cycle shops.
Here is a link you can take a look at.
http://www.webbikeworld.com/motorcyc...le-cleaner.htm
Old Jun 11, 2009 | 02:25 PM
Pine Tree's Avatar
Pine Tree
MODERATOR
Originally Posted by utz
is it ok to spray simple green all over the bike paint and chrome then rinse it off...
I would suggest NOT doing that.
Regular Simple Green straight out of the bottle might be a bit too concentrated to leave on any length of time. Many have reported streaking with high concentrations (I think the bottle says to cut it 20 or 30 to 1 for light cleaning).
WFIW, Simple Green Aircraft is also available. Both recommend dilution for light cleaning.
Personally, I would not allow any product to sit of the finish for more then a few seconds...again, that's just me.
Old Jun 28, 2009 | 12:31 AM
Nightrider2's Avatar
Nightrider2
I wouldn't use simple green on anything with a shiny finish.
Old Jul 8, 2009 | 04:50 AM
Potato_Potato's Avatar
Potato_Potato
Do not use it to wash your bike with. What you want is a good quality car wash soap that contains a water softener. Beyond that it can etch aluminum and cause rusting of steel.
Google it lots of bad stuff; Causes metal fatigue, antique toy restorers use it to take paint off, and it goes on.
There is an aircraft safe formula, that is safe for bikes, but it is not the one they sell at stores. You have to get it at FBOs.
After all that I will say that I use it diluted to clean the undercarriage, especially after I change oil - but I rinse it with a ridicules amount of water.
camshaks
Feb 16, 2011 02:51 PM
Coffeeman
Mar 17, 2010 07:13 PM
Jessie
Detailing
Dec 13, 2009 05:43 AM
Paul.C.
May 21, 2008 01:09 PM
wedwards
Dec 25, 2007 07:58 AM
