Gunk on the Rims
Old Jul 16, 2005 | 10:38 PM
Motorcop's Avatar
Motorcop
1st Gear
Default Gunk on the Rims
I have a '97 RKC. Both tires have gunk built up all around the rims and I have tried everything to remove the substance to no avail. I have used Simple Green, Blue Magic, 409, etc. I have embedded photos and begging for help. Does anyone have any recommendations of what I can use to remove this. Thanks for all the suggestions.....
[IMG]local://upfiles/3174/6243C6C5E755414A8793871DE55C04A9.jpg[/IMG]
[IMG]local://upfiles/3174/C2AFFB52238F4FC9B1446A7DD5AC392E.jpg[/IMG]
Old Jul 17, 2005 | 03:20 AM
Cool Breeze's Avatar
Cool Breeze
Default RE: Gunk on the Rims
I used the HD metal polish. It's the same as S-100. Worked great for me, just took a little elbow grease
Then use a little WD-40 to keep the grime off.
Old Jul 19, 2005 | 06:29 PM
HDF Tech's Avatar
HDF Tech
I've uses NEVR DULL, it's a cotton wadding and works well to polish and removes some nasty stains. It will make your hands really black because of the aluminum but it washes off.
Old Jul 31, 2005 | 03:59 PM
blkfalc4's Avatar
blkfalc4
Aluminum Mag wash, has muriatic acid, that is used for cleaning and shining aluminum.
Old Jul 31, 2005 | 04:02 PM
pilot1996's Avatar
pilot1996
Careful when using muriatic acid...it will screw up some stuff. Don't breathe it, wear gloves, etc!
Mac
Old Aug 20, 2005 | 01:10 PM
Greywolf's Avatar
Greywolf
There is also Symichrome and Mothers Mag & Aluminum cleaner.
Old Sep 18, 2005 | 11:58 AM
BirchwhiteHD's Avatar
BirchwhiteHD
I have the same problem with my rims,i'm using the symichrome polish,takes for ever to rub these stains off,but it does look better where i have done it,will be a good winter project,lol I'll have plenty of time
mike
Old Sep 20, 2005 | 10:47 PM
Heritage1's Avatar
Heritage1
1st Gear
Hello,
I've tried mild abrasive polishes and have had good results...products such as Autosol or Flitz might be worth trying on your rims. It will take some elbow grease but if superficial, these polishes are good at working them out.
Good Luck.
Old Sep 20, 2005 | 10:58 PM
blkfalc4's Avatar
blkfalc4
Personally, for AL, I'd take the rims off the bike, clean em, use muriatic acid (diluted), and have them clear coated to prevent further build up.
But, thats just me [8D]
Old Nov 3, 2005 | 03:00 PM
ultravista's Avatar
ultravista
I usually use Castrol Super Clean, it's a detergent similar to Simple Green. In my opinion, it is a far superior product for removing grease, grime and road junk. Once clean, I then use Mothers polish.
