not getting fuel. bike won't start HELP
Old Sep 24, 2014 | 01:48 AM
dudshep31's Avatar
dudshep31
Does this model have the filter in the tank?
Old Sep 24, 2014 | 12:48 PM
fwb35's Avatar
fwb35
It probably is the pet **** diaphram or the vacuum line. Both are easy fixes
Old Sep 24, 2014 | 06:56 PM
skinman13's Avatar
skinman13
I am pretty sure it does...my '01 SG has the same setup with an internal filter as part of the petcock assembly according to my manual but ya gotta empty the tank and take out the valve to clean or replace it...
Old Sep 24, 2014 | 07:05 PM
skinman13's Avatar
skinman13
Not expensive to replace yourself if the valve is bad...
Kutter HD prices
61338-02 new valve body $30
62170-02 replacement filter $4.07
Old Sep 24, 2014 | 09:44 PM
apetterez's Avatar
apetterez
Answered my own question. The problem was that my battery was low or dead and I couldn't get enough vacum to get fuel to carb. I used starter fluid to get bike started after charging battery for a bit after bike got started it had enough compression to push fuel out of petcock to carb. All was well after that
Old Sep 25, 2014 | 06:39 PM
skinman13's Avatar
skinman13
Something sounds weird here...there should be enough fuel left in the carb bowl to fire the engine even if the battery is down around 9 volts during the start cycle. And, even if the engine turned over at all, there will enough vacuum coming from the engine to open the valve and fill the bowl even if the volts are too low for the firing system to work.
I am thinking that you may still have an intermittent problem with the valve or your fuel filter is dirty...with a dirty filter, you usually do not see a problem until the fuel level gets low. In either case, if you have an intermittent problem or dirty fuel filter, you will know soon enough.
Range
Engine Mechanical Topics
Feb 28, 2017 12:22 PM
Bill Mills Jr.
Carburetor Related
Aug 1, 2016 12:33 PM
taizer
Jun 29, 2015 07:11 AM
apetterez
Sep 24, 2014 02:53 PM
burgerusmc
Nov 30, 2012 09:26 AM
