risers
Old Apr 11, 2007 | 12:27 PM
ny06fxdb's Avatar
ny06fxdb
Default risers
what is the max riser hight I can use with stock mini apes & stock cables on my 06 BOB.
Old Apr 11, 2007 | 05:47 PM
Noride's Avatar
Noride
Default RE: risers
I didn't keep my clamp and ape set up, instead i opted for a T-bar. I can't tell you exactly how much wiring there was there but my bars have a ten inch rise straight up and there was a wood amount of wiring left. Enough wiring that it needed to be shortened by my wrench. I think you might be able to get away with a three inch riser and be alright. Besides anything longer and in my humble opinion the set up looks funky and you might even get some bar wobble if you don't upgrade the bushings.
Old Apr 11, 2007 | 06:04 PM
steelcowboy's Avatar
steelcowboy
Default RE: risers
I didn't measure but I bet there was at least 4" of play in mine when I pulled it all out
Old Apr 11, 2007 | 10:37 PM
Noride's Avatar
Noride
Default RE: risers
Wood! Jeez, I need to go back to school!
Old Apr 11, 2007 | 11:23 PM
mdog2222's Avatar
mdog2222
Default RE: risers
I've got 4" risers on my 07' fxd with drag bars. The stealers didn't have to do any re-wiring. I've got my heart set on a tank lift and so I think that i'm going to try to stretch to 6" risers. Do any of you think that I'll have enough wire or play in the stock brake/throttle/idle cables to get away with this???
[IMG]local://upfiles/28108/5C27FA7E829D49069A9BC031355A4DF0.jpg[/IMG]
Old Apr 11, 2007 | 11:44 PM
CHEESE's Avatar
CHEESE
Default RE: risers
I went with 4" risers and had to replace clutch, throttle, and idle cables. I had to bend the hard part of the brake line, and the wiring had plenty of slack. If you change the risers, you'll have to do the three cables. Here's what it looks like:
Old Apr 11, 2007 | 11:47 PM
Cabo's Avatar
Cabo
Default RE: risers
NY.....I'm thinking of doing the same thing. Was hoping that someone had the exact set up.
Old Apr 11, 2007 | 11:49 PM
Cabo's Avatar
Cabo
Default RE: risers
There ya go. Thanks Cheese...Any chance you have a pic with side view?
Old Apr 12, 2007 | 08:19 AM
crfranklin65's Avatar
crfranklin65
Default RE: risers
I put 2" pull backs on mine from Drag Specialties and did not have to change any cables.
AJD
General Topics/Tech Tips
May 31, 2015 04:03 PM
ltcurt33
Jun 18, 2011 11:20 PM
firebrick
Oct 15, 2009 07:46 AM
hogcity5
Jan 4, 2009 11:01 PM
2StrongHayn
Aug 25, 2007 03:32 PM
