Fuel Gage Removal
Old Oct 5, 2014 | 12:07 PM
jbersaglia's Avatar
jbersaglia
6th Gear
Default Fuel Gage Removal
Wanting to replace my 2013 Wide Glide's fuel gauge and fuel cap with the HD LED set. I looked up the instructions and it said "remove old gauge per service manual". Problem is, I can't find a service manual for this model. Anyone know of a how-to video on gauge removal?
Old Oct 5, 2014 | 02:18 PM
adm's Avatar
adm
Go buy a 2013 Dyna manual from the dealership. Expensive, but worth it's weight in gold.
But.... if it's the same as 2014 Dynas, which it probably is, just pull the gauge up to remove. The wiring from it goes down through a tube through the fuel tank to a connector under the tank. You should be able to either undo the tanks fixings and push the tank back a couple of inches, or remove it entirely, then separate the connector halves.
You will then need to either remove the pins from the connector, or cut the wires. Then you can pull the wiring out. The connector is too big to fit through the tube that goes through the tank.
The new gauge install is the reverse. Thread the wiring through the tank, crimp pins on the wires, click them into the connector shell. Mate the connector halves.
There's also a bit of fussing around with the LED gauge and the holder to fit it into the tank, but it's just a few screws.
Old Oct 5, 2014 | 07:30 PM
Mr Bentwrench's Avatar
Mr Bentwrench
I guess this also addressed my issue of how to remove the gauge when repainting the tank.
Old Oct 6, 2014 | 10:23 PM
LAFO's Avatar
LAFO
Hope this helps.
cruzomatic
Dec 5, 2012 10:49 AM
Vikingnomad
Jun 25, 2008 09:38 PM
Shoe
Jun 8, 2008 11:36 AM
denicko
Jun 2, 2008 10:56 PM
Nofear6372
Apr 12, 2006 02:09 AM
