I recently had the local dealership do a stage one upgrade to my Street Bob and installed V&H Big Radius 2 into 1 pipes. Also I had the Screaming Eagle street tuner added. I love the look, and I love the sound when I am accelerating but when down shifting or when I let off the throttle there is a lot of popping. A friend who has a 2-1 pipe says that is normal for this type of pipe. I guess I'm looking for some more feedback. Is this normal or does some fine tuning need to be done. Thanks in advance.
I did too on mine even with the HD tune. Than I added a Dynojet Power Vision; and the popping is gone. Plus lost ten pounds and my hair is thicker. Actually it is true the popping did go away, I wish on the other.
Thanks for the response. Not sure I'm ready to drop another 4 or 5 hundred into the bike at this time. I'm hoping there may be another option.
You need a tune. Took the decel pop out on my ultra with a PC3 and a map from Fuelmoto.
Also if I had the cable to hook the tuner to the bike should I be able to do this at my home or would I be better off letting the dealership handle it?
Very easy with the PC tuners Jamie at Fuelmoto will load with a map and it is simple plug and play at the ecm, takes 10 minutes
