The cat is easily removed. Requires cutting into the pipe and welding after the cat is pried out. Very easy. The stock muffler is also very easy to modify. Go into the end with a 3 1/2" hole saw, pull out the baffling remove the fiberglass. From there you can modify like you want. I am cutting down the baffling and welding the end back in.
FWIW HD installed a new lighter muffler for 2015 FLD's, presumably to reduce the vibration associated with the exhaust system.
Some have had it reduced by installing the optional Nightstick slip-on, aftermarket complete replacement exhausts, and tightening the saddlebag mounting attach points with wraps of tape and O-Rings to limit movement.
