superglide drag bars
Old May 16, 2007 | 01:56 AM
  #41
Splatter's Avatar
Splatter
Default RE: superglide drag bars
ORIGINAL: DGlide04
Thanks, here is the part list I used for my upgrade, they were all bought from Zanotti's in Butler, PA, the prices I have are what I paid 2 years ago so they may have changed a bit:
Speedo/Tach Rear Cushion 67104-95 5.15
Speedo/Tach Front Cushion 67121-95 5.15
Y- wiring Harness 68850-04 83.40
Rear Cover/Bezel Kit 74541-00 7.16
Chrome Dual Bracket 67294-04A 81.00
Tachometer 68941-04 100.50
There may have been a couple of other small hardware items, but this is the best list I can put together w/o pulling dozens of receipts for the work done over the years. The more stuff you buy, the better a deal you can get on your shipping. The dual chrome bracket comes with the idiot light holes in it so it will accept the FXD/FXDX light set and the lights (see the attached) are included with the wiring harness, simple plug and go, no splicing, no hassle.
Gary
Gary -- I used your parts list to put the speedo/tach combo on my 07 Super Glide this weekend. Worked like a charm. The speedo kept all its original functions -- trip meters, clock, 6th gear annunciator and so on. And the tach works perfectly.
The Accutronix bracket is also available from Zanotti's. My setup was slightly different in that I was using stock bars with Harley 4" pullback risers. The risers are not 1-inch; more like 15/16th, so I had to cut a bit of innertube to shim the bracket -- I perfer to think of it as "rubber mounting the instrument cluster."
There wereonly two minor problems: The harness is a few inches shorter than the stock Super Glide harness, so I have the connector outside the fork stem and had to weatherproof it. The other problem is that the idiot lights are lamps, not LEDs so my idiot lights are all white now instead of colored. I can live with that.
Thanks very much for posting this. I really, really wanted a tach on my Dyna.
2007z71
Jun 5, 2011 03:36 PM
AdrianVall
Jan 23, 2009 06:57 PM
jkeeton81
Dec 24, 2008 10:37 AM
fire228
Jul 20, 2008 07:51 PM
drrandall1
May 22, 2007 05:15 AM
