I have a 1996 dyna glide convertable fxds. A while ago I was riding back to Vegas from LA during a pretty heavy rain storm when some jerk slammed his brakes which caused me to lock mine up and almost rear end the guy. I had to swerve off the road to miss hitting the truck. Anyway, in the midst of all that, I must've been instinctually trying to down shift. I had to ride 60+ miles back to Vegas at 50 mph in the break down lane. After I got home I looked at the bike and saw that my shift linkage had just disconnected. It didn't break. So I tried reconnecting it and I can't shift the trans at all. I put the bike up on a motorcycle jack and turned it on. Still can't shift. When I disconnect the linkage I can shift the trans from first to third by hand. Can't seem to get it into fourth gear whether the bike is running or not.
Also, I have mid controls and the linkage interferes with the engine. I'm assuming that's also obviously not supposed to happen. I don't want to take things too far apart in fear of not being able to put them back together. I'm moderately mechanically inclined since I work in an auto shop but transmission problems are out of my realm. Any ideas on what I should try or what could be wrong?
Thanks in advance!
Reason: spelling
well that sucks, atleast you made it home, I don't know much about these things myself, even though I have accidently downshifted without clutching a few times on motorcycles and it has never damaged my transmission. the first thing to is obviously re-connect the linkage and then work with it some more to see if you can get it to work..
beyond that try searching the forums for similar problems.
good luck to you, I'm sure someone will over better advice.
How else would I know that it's loose? Would it physically move up and down or in and out of the trans? I'll have to mess with it when I get off work tomorrow.
I've had the shift arm come loose, not the shaft, on both my Twin Cam 5 speeds.
The pinch bolts are grade 8, but they still stretch.
Just wiggle it, if it moves side to side, it's loose on the shaft.
It has to be bent or loose to be scraping the engine.
I agree with the guys above. This just happened to me last weekend, went to grab an upshift on the onramp and the shifter moved 4 inches but no gear change. Got home by shifting with my heel on the trans arm. I'm in the middle of replacing the shift rod now. Waiting for a new belt too since the entire primary has to come off to do the repair. I'm in Vegas too if you wanna link up and check out the repair you too will be doing too soon lol.
