Dealer Handlebar Install Cost
Old Dec 11, 2014 | 02:29 PM
Jjack010's Avatar
Jjack010
Do it yourself and go buy a bunch of beer with the savings.
Old Dec 11, 2014 | 03:15 PM
PushingLuck's Avatar
PushingLuck
6th Gear
Not surprised at the $400 quote. I was quoted $380 by my local dealership. Ended up doing it myself. Took about 2 and a half hours. That is including the extended cables and brake line. Have a case of beer and take it slow. Not a very difficult install. Just don't drop that brass piece out of the right side switch housing. It's a pain to find if it falls out.
Old Dec 11, 2014 | 03:19 PM
loopie's Avatar
loopie
the FERULE it pays too have a couple off spare one's, hard too find on the floor sometimes
Old Dec 11, 2014 | 06:46 PM
skinman13's Avatar
skinman13
I am not trying to call you out, but I am a damn good mechanic with many years of experience under my belt, and I am having difficulty believing anyone can change the handle bars on any Harley, including cables, switch housings, grips, extending wiring, and replacing the brake line and bleeding the brake in 150 minutes...while drinking...and do a job worth a ****...if you can do this as you claim, then you are one hell of a tech and I tip my hat to you...just say'n...
Hell, it took me close to an hour just to bleed the brake line!
Old Dec 12, 2014 | 03:43 AM
loopie's Avatar
loopie
I charge a bottle off jack daniels, plus parts at cost too change bars, easy done, a carton off beer too service all oils plus parts, stuff takeing it too a stealer,
Old Dec 12, 2014 | 04:10 PM
PushingLuck
6th Gear
You can call me out if you want, not gonna hurt my feelings.
I can't say it was exactly 2 and a half hours, but it was somewhere around that. Could have been closer to 3. I didn't time it.
This was external wiring on a set of Biltwell risers and bars. Changing over the switch housings wasn't that bad because there was no wiring to extend,just swapped over. Had my uncle there to help bleed the brakes and hold the tank up while I ran the cables to the tb. That and the cable adjustment was the biggest p.i.t.a, IMO. Plus the lift and my tools from when I was a tech at a dealership helped out. Harley wanted 3.5 hours of labor to do it, and when was the last time you didn't hear them pad the time a little?
Rogowski
Feb 14, 2019 07:07 AM
gize
Feb 27, 2014 03:20 PM
Dakotazeb
General Topics/Tech Tips
Feb 16, 2013 01:33 PM
1sweetglide08
Aug 6, 2011 12:35 PM
joel85
Feb 2, 2008 01:52 PM
