crankcase ventilation
Old Dec 8, 2014 | 08:21 AM
jmb79's Avatar
jmb79
Originally Posted by 1stfxdwg
but there will be "0" horsepower/throttle response increases/changes from this mod. im not raining on what you did, it is great work at concealing the can, equal to a factory component!.
Over time, with the crankcase venting into the air cleaner and throttle body, you have sticky build up which reduces air flow. No, I have not measured the difference between a clean a/c and tb versus ones that are fouled up, but I've seen some pretty gunked up (that's a technical term) a/c and tbs.
Old Dec 8, 2014 | 08:48 AM
BigDogIdaho's Avatar
BigDogIdaho
I would think you would get better performance, if nothing else like was mentioned earlier, just clean. Did I miss you posting what you did with your horn? Tossed it in the parts bin?
I have the DK set up (love it by the way) and have noticed a little blow by on my bike. Usually right after getting the bike serviced. I noticed once the oil level gets a little lower that stops. You might play with your oil level a bit and see if that helps. Maybe put some sort of filter in there to stop smelling oil? Maybe a piece of washable filter media?
Old Dec 8, 2014 | 10:50 AM
fxdc_9613's Avatar
fxdc_9613
Originally Posted by blueangel73
Could the oil build up over time lead to hard/trouble starting when the engine is hot? I like this mod, can you list what and where you picked up your parts. I would really like to get any of the oil out of my intake if I can.
Not sure about the over time, I dont think so. Like i said, i didnt come up with this idea, i based it off of another forum members concept. I feel like if that was an issue, he would've posted about it.
parts:
- Catch can from Amazon, by HDM performance (or something like that, its a go-kart company) about 20$
- Rubber plumbing seal, comes in a square from Lowes
- Electrical conduit hangar, i think 1.5 inch also from Lowes
- 1/4" fuel line from auto parts store
- two 1/4" brass barbed fuel line connectors, basically just a straight fitting to connect two hoses
- 1/4" brass barbed t-fitting
- a drill to drill the stock air cleaner backplate
where's the horn mounted now?. excellent engineering!, ill admit that it will eliminate the oil being routed through the combustion chamber to be burned off. your piston tops will probably be cleaner as will the throttle body. but there will be "0" horsepower/throttle response increases/changes from this mod. im not raining on what you did, it is great work at concealing the can, equal to a factory component!.
I disconnected the horn. I have literally never used. I may look into getting the DK Custom horn relocation kit when i order my intake...maybe. To me it feels more responsive, but even if the power is the exact same, my purpose wasn't for a performance mod. It was for overall health, cleanliness and to stick it to the EPA. I also am going to do a DIY catch can for my car soon.
I just got rid of the horn, never used it. The only downfall is that there is very little room to play with. I don't want to move the can down too much more because than it will show outside of the cow bell. I'll look around, maybe a sponge-like filter element might work.
Old Dec 8, 2014 | 11:55 AM
BigDogIdaho
That's what I was thinking of. Something like a small sponge. If you can pull it out and clean it, should be good.
Wonder if you can make a catch can....looks like it might be doable with some PVC pipe and a fitting or 2.
Old Dec 8, 2014 | 12:06 PM
jmb79's Avatar
jmb79
Did you read the thread? A catch can is exactly what this thread is about. fxdc_9613 fashioned an external breather system that empties into a catch can!!!
Old Dec 8, 2014 | 12:22 PM
BigDogIdaho
parts:
Oh you are right....he MADE a catch can that he purchased from Amazon ???
Old Dec 8, 2014 | 02:49 PM
fxdc_9613's Avatar
fxdc_9613
I thought about making a catch can, then found a ready made one for fairly cheap. Saved some effort, spent some money and just modified slightly.
Old Dec 8, 2014 | 07:07 PM
Ape_Hanger's Avatar
Ape_Hanger
I just ran a hose straight down between the motor and transmission.
Old Dec 8, 2014 | 07:08 PM
fxdc_9613's Avatar
fxdc_9613
Yeah, that's definitely am easier option. I just wasn't a fan of all that hose showing, wanted something much more concealed. To each is own
Old Dec 8, 2014 | 07:41 PM
Qdog002's Avatar
Qdog002
9613, this may be a dumb question but shouldn`t the tubes to the catch can be lower than the air cleaner assembly so it does not have to blow the oil up?
