Barnett HD spring 502-00-01008
Old Dec 27, 2014 | 07:31 AM
HD Pilot's Avatar
HD Pilot
Originally Posted by HD Bobber
Does barnett ONLY offer the 500lbs version? Thought they had another option?
They make 502-00-01004 which is listed as a "Standard Replacement", so probably about the same as a stock one.
Old Dec 27, 2014 | 08:55 AM
target64's Avatar
target64
Im running the barnette 502-00-01008 clutch plate was told from the company it was 340 lbs. the pull was quiet a difference over stock but slipped on the dyno after a couple pulls. installed the AIM VP95LT VPC and no more slippage and the clutch pull with the engine running is very acceptable.
Old Dec 27, 2014 | 09:09 AM
rsking45's Avatar
rsking45
I'm goin to performance Harley today,which is a 2.5 hr round trip, to get the SE spring. The local dealer doesnt stock ****. I'll let ya all know what difference there is between the two.
Old Dec 27, 2014 | 10:12 AM
Reindeer's Avatar
Reindeer
I had the Barnett HD spring for a year. Suffered through Sturgis traffic with it. I ended up ditching it for a Aim VPC, which I'm very happy with.
Old Dec 27, 2014 | 11:01 AM
2007fxstc's Avatar
2007fxstc
Default cable life?
And this makes me wonder about how long my cable is gonna last?
Old Dec 27, 2014 | 01:21 PM
HD Pilot's Avatar
HD Pilot
Yeah, the lbs I was quoting comes from "Max" over at HTT who tested multiple clutch springs - I think he is pretty accurate with his methods and it seems like everybody that has used both say the SE is significantly easier.
Old Dec 27, 2014 | 04:34 PM
JMummery's Avatar
JMummery
So got a question, at what horse power or mileage does the stock clutch spring needs to be changed? Also what's the benefit for going aftermarket ?
Old Dec 27, 2014 | 07:27 PM
izhd's Avatar
izhd
Did you guys think of using easy pull clutch with Barnett or se?
Old Dec 27, 2014 | 09:13 PM
HD Bobber's Avatar
HD Bobber
90hp+ I would change, so cam swap along with new spring.
I've heard bad things about those, such as clutch slippage & engagement issues.
Old Dec 27, 2014 | 10:09 PM
rsking45's Avatar
rsking45
I installed the SE spring tonight ,and the pull is alot easier over the barnett ,but a little stiffer than stock.I think it will work good for just doing cams.
The parts guy at Harley did try to talk me into going with the SE variable pressure clutch,but for $300 and only done cams I think it will be a waist of money,unless just doing the spring doesnt work out.
