I'm having trouble from my fat bobs headlights. They will turn off at random. I've narrowed it down to the ground wire in the connector not forming a good enough connection but whether the connector isn't holding it in place right or the tang inside the connector is bad is up for debate. I'm tired of messing with it so I go to buy a new harness and connector but my parts guy at the dealership can find the connector but not the harness from bulb to frame; he's only able to find as a complete assembly with headlight for 359 bucks. I'm looking for a part number if any of you have access to them for a 2013 fat bob.
It's the connector at the frame and guess I'm going to have to grind down a rod to form a thin enough pick. Lost the old one and thought my precision screwdrivers would work well enough
Unfold a small paperclip and flatten one end with sandpaper...
...I'm going to have to grind down a rod to form a thin enough pick...my precision screwdrivers would work well enough
and, folks, this is how you screw up a connector so that the contacts will not lock in and you get headlights and things turning off and on randomly....
spend the $10 and get the right tool...do it once, do it right.
