sprocketing
Old Jan 31, 2015 | 10:25 PM
dirtdobber's Avatar
dirtdobber
By going 30/70 you will lose some cruising speeds but I doubt you will hurt the top end speed. Most engines will not red line in 5th and I have never run one that would hit the limiter in 6th.
I Personally I don't care for a 30 tooth crank gear. I prefer to have my compensator sprocket.
I did a reduction in the first 3 gears but I did it through the transmission. Kinda costly I may add.
Old Feb 1, 2015 | 08:34 AM
vdop's Avatar
vdop
I agree, why have a Harley with enough gear for 170mph if it'll never make the power to get there? I put mine at 3.17:1. 25/55 w/chain and +3 on clutch basket. On the dyno it hits 150 in 6th at about 6900rpm. I'm pretty confident it'll do it on the street. I set the limiter to 7100 and went for it one time, shift light came on at 6700 but i was coming up on cars quickly and had to shut it down, it was still pulling pretty good though.
Old Feb 1, 2015 | 11:13 AM
Suede Blue Man's Avatar
Suede Blue Man
Your bike is a beast and I want to ride it, and I doubt I'm alone there!
Old Jun 8, 2017 | 02:41 AM
wholehog's Avatar
wholehog
2nd Gear
Just wondering, if i used a 68 tooth sportster sprocket,(1 inch belt width),part #40444-07 .
would i require a spacer to mount it to my 2013 fat bob?
Old Jun 8, 2017 | 08:15 AM
619DYNA619's Avatar
619DYNA619
I had a 30t Andrews in the front and a 68t sportster pulley and a spacer in the rear on my Fat Bob. Stock belt fit fine. I switched to chain drive since then.
Old Jun 8, 2017 | 01:59 PM
wholehog's Avatar
wholehog
2nd Gear
How wide was the spacer,if u can remember ?
Just looking to the naked eye without measuring I'm thinking about 3/8 roughly.
Old Jun 8, 2017 | 02:08 PM
619DYNA619's Avatar
619DYNA619
i dont remember off the top of my head but if I remember I'll measure when I get home tonight.
Old Jun 8, 2017 | 02:21 PM
wholehog's Avatar
wholehog
2nd Gear
Cheers man.. that would be great
Old Jun 8, 2017 | 07:58 PM
DrewNJ's Avatar
DrewNJ
probably easier to run the OEM international pulley. No spacers needed.
​​​​​https://www.hdforums.com/forum/dyna-glide-models/1004601-68t-rear-pulley-swap.html
Old Jun 8, 2017 | 09:42 PM
maddghost's Avatar
maddghost
Originally Posted by 11fatbean
wouldn't I see more acceleration with a tooth drop off of front pully
Change the rear change the front it all balances out in the end.
Three more things:
Front sprockets usually go two teeth at a time
What you gain on take-off you loose on the top end
THERE IS NO REPLACEMENT FOR DISPLACEMENT
BlockHead96
Mar 9, 2015 07:53 AM
hddee
Sep 30, 2012 02:14 AM
nhb006
Jun 15, 2012 05:39 PM
rix181
General Topics/Tech Tips
Jun 7, 2012 12:28 AM
maineac
Mar 4, 2012 08:35 PM
