Brake dis discolored from heat - How to restore
Long story short, my front disc got overheated and changed color...anyway to get it back to normal?
I was wondering about heating it up some and using Easy-off oven cleaner...worked on my pipes.
I will probably have to sand it or something.
Anyone have a solution?
RE: Brake dis discolored from heat - How to restore
The thing to worry about is not that the color changed, but what it has done to the heat treating. Do what you will to restore the color, but keep a close watch for warping and small stress cracks.
The stuff they use on stainless steel cookware might do the trick, and most of that is very close to a wipe-on, wipe-off polish.
Ok, here's the long story.
I changed my bars but didn't have the right front brake line.
I thought i could just cap the caliper off and ride the bike without a front brake tillthe linearrived.
I wanted to test out the new bars so i went for a ride.
i only got less than a mile away when I felt the front end dragging a little. The pressure built up in the caliper and was squeezing the pads.
I turned around and went home.
I rode about 1 mile or less with the front brake dragging enough that I could tell it was on.
I don't really think major damage was done because the brake pads have already worn away the discolored area where they grab.
I just wanted toclean up the area around it.
I may not even mess with it now that it's finally getting nice enough to ride!
Mascman
06-04-2007 09:58 AM
2000, brake, disc, discoloration, discolored, harley, heat, hub, king, motorcycle, polished, restoring, road, rotors
