front turn signal relocate question.
Old Apr 18, 2007 | 09:35 PM
baxter's Avatar
baxter
Default front turn signal relocate question.
im waiting on my shocks so i might as well get this done although i dont feel like it. i was wondering where everyone pulls their signal wires from for their relocation. i was thinking slice the mesh cover and pull from right under the handlebars rather then try to yank the mesh cover out of the frame and pull out there just to have more wires streaming outa the frame. whatya suggest? is the wire inside the meshing look the same as the exposed wiring that runs from the signal into the switch housing?
Old Apr 18, 2007 | 09:36 PM
baxter's Avatar
baxter
Default RE: front turn signal relocate question.
yes i know its time to buy a service manual but ive done well so far.
Old Apr 19, 2007 | 02:12 AM
phreak's Avatar
phreak
ORIGINAL: baxter
Let me see if I can get this straight..... The wiring you see exposed phrom the bottom of the handlebar controls to the signals is a continuous cable. It passes through the controls housing, and is inside the cloth(mesh) sleeve with the rest of the control wiring running back to a connector inside the phrame.
Disconnect it phrom the connector in the phrame. Remove the wires phrom the connector then pull it through the cloth(mesh) sleeve and out of the bottom of the control housing. Remove the signals phrom the bottom of the mirrors, and relocate. Push the wiring back through the openings on the sides of the phrame reattach to the connector, reconnect the connector.
Of course you can always cut and solder the wires too, but basically it is one continuous wire phrom the signals to the inside of the phrame.
Old Apr 19, 2007 | 02:23 AM
stevieg's Avatar
stevieg
Where are you phrom? phoenix?
Old Apr 19, 2007 | 05:39 AM
Rauzer's Avatar
Rauzer
I'm not quite following your post. I just took the wires that go to my turn signals and cut them shorter when I moved mine. [sm=confused06.gif]
Old Apr 20, 2007 | 12:14 AM
JayFromPa's Avatar
JayFromPa
ORIGINAL: Rauzer
Why cut them shorter? I pushed mine back into the frame.
Old Apr 20, 2007 | 01:39 AM
thebestofindica's Avatar
thebestofindica
I used the 49mm kuryakyn fork mounts instead of stalks from moco. See here for information on removing turn signal wires from connectors. The only way to do it in my opinion. Good luck
https://www.hdforums.com/m_1328001/tm.htm
Old Apr 20, 2007 | 07:58 PM
compgeek789's Avatar
compgeek789
I don't have the best picture of my wiring, but what the heck. If you look closely, you can see what the wire looks like without the mesh sleeve. I went with the H-D brand relo kit. I'm kinda wishing I went with the Kury kit instead. The H-D kit sticks out a bit far, in my opinion.
[IMG]local://upfiles/27035/1AF54D8A821E43FCB49E5A80DEE917AB.jpg[/IMG]
[IMG]local://upfiles/27035/19F00537365C4AA888EFA1A60E6BD65F.jpg[/IMG]
Old Apr 20, 2007 | 08:38 PM
jamman's Avatar
jamman
here's pics of the moco Stalks cut down..
Old Apr 20, 2007 | 10:18 PM
Rauzer's Avatar
Rauzer
Here's mine with the Kury ones...
[IMG]local://upfiles/11457/619A4F79BD02458C81DAD3428F454869.jpg[/IMG]
