Forward Control bore size?????
Old Apr 18, 2007 | 11:27 PM
2000Ironhorse's Avatar
2000Ironhorse
Default Forward Control bore size?????
Changing out the stock mid controls on my 2000 FXDL. Looking at JayBrake brand. Problem is they have two bore sizes listed for my year. I am not sure why. Can anyone explain how to determin what size is right? they list a 5/8 and a 3/4 bore. Called the stealer and was told 9/16 any idea's??
Thanks!
Old Apr 19, 2007 | 01:40 AM
mtnlvr's Avatar
mtnlvr
Default RE: Forward Control bore size?????
Depends on how many pistons in your caliper(s) and how big they are or if you're ever planning on upgrading brakes down the road.
I found some good information searching around a month ago, give it a try. Lots of articles on this.
A bigger master cylinder bore will move more fluid but have a spongier feel, smaller bore moves less fluid but has a firmer feel...I think. Also, I believe a smaller bore exerts more PSI on the rotor?
Old Apr 19, 2007 | 02:10 PM
2000Ironhorse
Thanks for the input.
Old Apr 19, 2007 | 02:44 PM
murphdog's Avatar
murphdog
Which ones are you looking at? All the ones I saw in their online catalog said 5/8".
Old Apr 19, 2007 | 05:14 PM
R Racing's Avatar
R Racing
I went with the 3/4 on my 2003 using there 6 piston caliper. I wanted the brakes to respond fast. So I figured with the extra pistons the bigger bore would be a good idea.It works great and is a hugh difference over the stock unit.
Jim
NELS
Shovelhead
Jan 1, 2018 01:18 PM
bucker18
EVO
Aug 20, 2012 03:59 AM
bparsel
EVO
Mar 8, 2011 12:58 PM
Capt_Locutus
Exhaust System Topics
May 13, 2009 02:05 AM
HDF Tech
Feb 13, 2006 05:11 PM
