does master cylinder bore matter
Old Aug 17, 2012 | 11:49 AM
bucker18's Avatar
bucker18
Default does master cylinder bore matter
iv been doing alot of research on converting my hand controls to a 96+ i found a great deal on a kit.http://www.bkrider.com/bkrider/skuse...iteria=SA30109 i have never messed with the master cylinder befor so i dont know what is on it . i have a 92 will this kit work or do i need a 9/16 bore.
Old Aug 17, 2012 | 12:09 PM
Dr.Hess's Avatar
Dr.Hess
All other things being equal, different size bores in the MC work like this:
Larger bore give you a firmer pedal (lever in this case) and will require more physical force to achieve the same braking effect (less leverage). Harder to modulate.
Smaller bore will give you a softer pedal (or lever) and will require less physical force to achieve the same braking effect (better mechanical leverage). Easier to modulate.
Now, is the difference enough to be a problem in this case? Probably not, but you will likely have to get used to the new "feel" afterwards.
Old Aug 17, 2012 | 02:21 PM
bucker18's Avatar
bucker18
ok good to know what would size would you recommend i dont like a really stiff leaver.
Old Aug 17, 2012 | 03:53 PM
dwatkins's Avatar
dwatkins
I have a 94 heritage and the bore is 5/8" stock so I'd say that's what yours is if it has the original controls.
Old Aug 17, 2012 | 04:34 PM
Dr.Hess's Avatar
Dr.Hess
You can't go wrong with the bore size the MoCo put on the bike to run whatever brakes you have on there now. That is, if they put a 5/8" MC on with the calipers you have on there now, then you can't go wrong with a 5/8" bore. If they put a 9/16" on with those caliper(s), then stick with that.
But, like I said, the difference in actual feel between 5/8" and 9/16" may be fairly small and not really noticeable. Do teh maths on the volume and stroke differences between those sizes and you might get an idea. You are talking 1/32"^2 * pi * stroke volume difference. There's always a certain amount of trial and error too.
Old Aug 17, 2012 | 06:22 PM
bucker18's Avatar
bucker18
yea ill just have to do some checking thanks for all the help
Old Aug 18, 2012 | 07:02 AM
Kabear's Avatar
Kabear
Actually it will be the length of the "stroke" of the piston that counts. A smaller bore in the master cylinder would require more movement in the brake lever to achieve the same "pressure" on the caliber piston to do the same amount of "work". Thus you don't have to squeeze harder/softer but longer/shorter.
Make sure that the lever is capable and has enough "travel" to do the work. And don't forget that the mc lever also activates the brake lite. So if you would go to a larger bore the brake caliber's pucks may be in full contact with the rotors before the switch is activated. I don't know but the switch position may be adjustable.
Think of it as changing sprocket sizes on the output shaft of the transmission. Go to a smaller sprocket and the engine has to turn more RPM's to get you down the road for the same mph's. And of course vice/verse.
Old Aug 19, 2012 | 05:40 PM
Spanners39's Avatar
Spanners39
If you fit a hydraulic brake light switch at the master cylinder banjo it overcomes any issues....I don't fit the stock switch any more....the hydraulic one is vastly superior to the stock switch.
Old Aug 20, 2012 | 03:59 AM
grbrown's Avatar
grbrown
Talking
In essence any small-bore master cylinder intended for Harleys is for single disc, the larger size is for twin disc. As the link says, that 11/16" is a twin disc set-up. It will even do twin rotors.....
ericfourzero
Mar 27, 2019 04:40 PM
Pothole914
EVO
17
Apr 4, 2017 04:13 PM
Road Star
Feb 7, 2014 02:58 PM
bensonjv
Wheels/Tires
Sep 21, 2009 07:57 PM
harldave
May 20, 2007 10:00 AM
