Master cylinder size
Old May 19, 2007 | 03:29 PM
harldave's Avatar
harldave
Stage IV
Default Master cylinder size
I want to replace the switches and levers on my 79 dyna superglide with newer stylechrome controls. But in searching, I see you need to know what size your master cylinder bore is. I have dual disk brakes on my front wheel. How do I tell what size my master cylinder is??
Old May 19, 2007 | 05:58 PM
thrillseeker's Avatar
thrillseeker
Default RE: Master cylinder size
I forget the sizes (9/16 and 11/16?), but your dual front brakes take the larger of the two options
Old May 19, 2007 | 06:16 PM
xmeter's Avatar
xmeter
You have to measure the ID of the Master Cylinder bore. It is the partwhere the piston is.
Old May 20, 2007 | 02:12 AM
sporty79's Avatar
sporty79
It should be a 3/4" bore, same as my 79 sportster. All the FX and XL models shared the same front brake setup from 79 - 83. Worst brakes H-D ever put on a motorcycle...
Old May 20, 2007 | 10:00 AM
harldave's Avatar
harldave
Stage IV
Thanks for your advice brothers. I assumed the larger of them would be better. I have ordered the 11/16 size off of ebay.
"Keep the shiney side up, the rubber side down and stay between the poles"!
DTTJGlide
Mar 20, 2010 10:17 AM
clowe
Feb 12, 2010 05:29 PM
Figstr
Nov 8, 2009 08:48 AM
bensonjv
Wheels/Tires
Sep 21, 2009 07:57 PM
02Sporty1200C
Dec 14, 2007 08:49 AM
