1999 Dyna Frame
Old Feb 16, 2015 | 02:17 PM
Killer614's Avatar
Killer614
Stage III
Default 1999 Dyna Frame
My frame has the ignition key hole on the right side like a Low Rider set-up. It also has mounts for mid controls. The VIN and factory plates come back as Wide Glide. Was this standard for the year or was the frame replaced by the factory? Thoughts plz?
Old Feb 16, 2015 | 03:11 PM
Mymojo's Avatar
Mymojo
6th Gear
I have a '99 DWG and my ignition is on the center console of the tank.
Old Feb 16, 2015 | 03:34 PM
Mr Bentwrench's Avatar
Mr Bentwrench
A factory replacement frame will be stamped with the exact same markings and numbers as the original. Do all the numbers match the title and is the title branded.
I just went through this on an '07 salvage/rebuilt.
Old Feb 16, 2015 | 04:18 PM
Azgunner's Avatar
Azgunner
Wideglide & Lowrider frames are the same part # & frame.
Old Feb 17, 2015 | 12:30 PM
Architect's Avatar
Architect
The all have the hole for the ignition on the right side of the frame. On the Wide Glide's they just put a sticker over the hole to hide it. So that is inconclusive.
The all have the threaded inserts for forward and mid controls. The factory just put the appropriate controls in on the assembly line. The other inserts got plastic plugs.
I even believe the frame rake is the same on those two bikes, Super Glide would be reduced rake.
A couple of pictures might help, but based on your criteria, now way to tell besides the VIN what the frame started life as.
Does anyone know if the neck is different to receive a narrow glide vs wide glide front end? I think the neck is the same as well. I really think the frame on the Low Rider and Wide Glide, stripped down to just the frame would be identical.
Maybe someone smarter has a different opinion.
EArthur999
General Topics/Tech Tips
Aug 4, 2020 07:44 AM
eliminator
Nov 16, 2017 02:37 PM
EArthur999
May 1, 2014 10:04 PM
rounder
Aug 3, 2008 02:25 PM
JBA111
Mar 22, 2008 02:48 AM
