How did you paint your tunrsignlas on late model streetbob
Old Feb 18, 2015 | 12:43 PM
AdamM's Avatar
AdamM
Originally Posted by tfalcon
Is there a special way to get the reflector out with out breaking it. I would like to do this as well.
Once the bulb is out you'll see that theres a small hole in the side of the reflector, I just stuck a small curved pick in there and pulled. Popped right out. The only thing holding it there is the rubber gasket
Old Feb 18, 2015 | 02:09 PM
tfalcon's Avatar
tfalcon
Alright thanks, I'll try that next time.
Old Feb 18, 2015 | 08:13 PM
JaronB's Avatar
JaronB
1. Disconnect quick release fuel line
2. Unbolt tank bolts front and rear and slide tank back a few inches watching the fuel cross over.
3. Remove plastic cover on the underside of the backbone.
4. Pull out the bundle of wires and the signal wire connections are the white and black connectors I believe.
5. Disconnect them remove the wires from the neck and disassemble the molenex connectors Molex connector disassembly. Draw the a pic of the wire color locations in the connectors before you take them apart
6. Unscrew the hand controls and the sigs and pull the wires through and now you have the whole assembly with the wires to do as you please with OEM Conduit with no cuts.
7. Paint/reinstall
8. Rebuild Molenex connectors
9. Route wires back into the neck, connect and reinstall plastic cover and gas tank.
I used the Rustoleum Appliance epoxy!! I had extra lens that I used so no paint got in where the bulb is.
I thought I had pics of the sigs, but here are the trees up close
The sigs are down on my forward controls and I painted the forward controls with the Epoxy too!
Kayakeur
Electrical/Lighting/Alarm
May 20, 2016 04:16 PM
bluharley
EVO
27
Jun 11, 2014 02:19 AM
KYFATBOB
Feb 15, 2011 11:23 AM
wiegs
Mar 26, 2009 10:58 PM
sgtrod91
Aug 21, 2007 08:02 PM
