New here, been following the Dyna section for some time. Picked up a Street Bob in January and do not know why i waited so long.
I seem to be noticing a slight speed wobble or something similar at speeds above 65. Seems to start shaking the bike a little bit and goes away right away when i put some good pressure on the bars. Sometimes gets a little uneasy feeling.
Any suggestions on what to look for or maybe add to help alleviate this? Stabilizer? Bike tracs straight as an arrow so it seems all aligned.
Id check tire balance and steering head adjustment.
+1
YouTube or Google search "fall away test"
It's not rocket science...... It's easy to adjust, especially in a dyna. It's something I do routinely. I live in Kansas, and in tornado alley..... It's super windy here, and the last thing I need is steering wobble.
I know your bike is newer, but the wheel bearings could be shot as well. Bearings can give a really uneasy feeling to your ride. Hope you figure it out.... Harley's are supposed to be fun to ride!
Good recommendations! Start with the easy, common, inexpensive solutions. Don't make things more complicated than they need to be. In addition to tire balance, make sure your tires are properly inflated.
How many miles on the tires?
What kind of tires?
How many miles on the bike?
I've found in the past that most minor wiggles/wobbles can be cured by replacing the front tire and/or fork oil. Head bearings, wheel bearings, spokes though obviously important maintenance items, do not typically cure this symptom.
Accessories like stabilizers should be used to optimize the bike's handling... NOT curing a problem that shouldn't be there!
I just hit 1800 miles, factory harley tires Michelin i think.
Has it felt uneasy since you first got it? Were you a sport bike guy before?
I ask because when I rode my first Dyna after being on nothing but sport bikes, it handled like a wet noodle in comparison.
All the basic checks recommended here are great starts, and I agree with making sure you fix the cause vice the symptom. Since your bike is so new, I highly recommend taking it in to the dealer with the complaint of "wobble at speed" and see what they come back with. If everything's in spec, then you may need to consider other options.
I've invested a lot of money and time getting mine to handle well at high speed, so if you're after that sport bike feel, be prepared to part with some cash. I've littered this forum with posts in search of decent handling. The good news is, most of upgrades are fun and rewarding if you like tinkering (and road testing).
My T-Sport used to wobble a bit around 100mph, then started doing it when going downhill fast...my tech buddy just had me give the stem nut 1/8 turn more than spec; cured...
