Pads touching rotors
Old Apr 23, 2007 | 10:37 AM
Bent Carhood's Avatar
Bent Carhood
Default Pads touching rotors
I just installed a frontHHI 4 piston caliper and the pads touch the rotor when thebrake is not applied. Is this normal?
Thanks in advance.
Old Apr 23, 2007 | 10:51 AM
voyager1's Avatar
voyager1
Default RE: Pads touching rotors
yeppers.it is norm :
Old Apr 23, 2007 | 01:55 PM
Bent Carhood
Thanks. It definitly keeps the wheel fromspinning when the bike is on the lift. Wonder how much power I'm loosingif both wheels are fighting the pads.
Old Apr 23, 2007 | 03:03 PM
tireater's Avatar
tireater
That don't sound right...you should be able to hear it make contact but there should NOT be a lot of drag. Make sure it is shimed right..the disc needs to be in the middle of caliper...
Old Apr 23, 2007 | 03:08 PM
glide05's Avatar
glide05
ya - what tireater said. if the rotor is centered in the caliper there will be light touching on both pads. if you can't spin the wheel when its off the ground, sounds like one side is dragging.
Old Apr 23, 2007 | 03:15 PM
but Ill try 2 try's Avatar
but Ill try 2 try
after many a brake pad replacement Ican say they do touch and make a soft contact friction noise but you should always be able to hand spin a wheel even on a car/truck, but especially on a bike. Go out and ride it for a bit and apply the brakes, if it jerks to one side that will help you solve which side needs adjustment. Of course if the wheel won't turn one side is going to be red hot before you even apply the brakes.
50Flathead
EVO
19
Apr 5, 2016 07:20 PM
iDodgimus
Apr 11, 2015 04:10 PM
Sammydogs64
Feb 2, 2014 12:23 PM
ScReaMnEagLE22
Dec 11, 2009 07:19 PM
Mr Wonderful
Mar 17, 2007 08:09 PM
