Keeping the pads from rubbing ???
Old Dec 11, 2009 | 10:19 AM
ScReaMnEagLE22's Avatar
ScReaMnEagLE22
Default Keeping the pads from rubbing ???
Is there anything one can do to keep the pads from being in contact with the rotor while going down the road or pushing the bike in the garage ? Seems as if its holding you back...
I know its not the same thing and weight is a major factor but my mountain bike has magnets built in to the calipers which pull the pads off the rotors when not using the brakes letting the wheels spin as free as possible.
Old Dec 11, 2009 | 02:25 PM
FastHoss's Avatar
FastHoss
Should not be enough pressure to hold you back.Sounds like they might need to come apart and be cleaned up.
Old Dec 11, 2009 | 03:04 PM
1sssickdeuce's Avatar
1sssickdeuce
SE22
of your scoot!!
Old Dec 11, 2009 | 05:11 PM
Alain's Avatar
Alain
i'm not sure but i always thought this was a normal thing with harleys
Old Dec 11, 2009 | 07:19 PM
RocketRocker's Avatar
RocketRocker
Those plastic cups (pistons) in your calipers should slide out when you take off the pads....those need to be cleaned due to carbon build up. The build up creates pressure onto your pads which rub against the rotor......maybe...but definitely worth a try.
smokindave
Jan 3, 2022 06:16 PM
buboje
Jun 9, 2017 07:43 PM
Streetrunner
Dec 17, 2012 12:40 PM
masterblaster
Jan 4, 2011 06:53 AM
tx-skydiver
May 13, 2010 09:26 AM
