2000 Dyna Rear Tire Width
Old Apr 23, 2007 | 04:49 PM
Maddogs700srx's Avatar
Maddogs700srx
Default 2000 Dyna Rear Tire Width
I have a 00 Dyna X. How wide of a rear tire will run on the stock spoke wheel with no other modifications?
Old Apr 24, 2007 | 01:26 PM
Jake88's Avatar
Jake88
Default RE: 2000 Dyna Rear Tire Width
Try this in the tire section? Maybe you will get more response? I would like to know as well because I have an 02 Wide Glide and was wondering the same thing? Good luck!
Old Apr 25, 2007 | 01:08 AM
fj4069's Avatar
fj4069
you can fit the screamin eagle 180 on the stock rim and you'll be all good.if you want to fit the 200 you have to go to a wider rim. how wide you ask, i don't know. seen a few manufacterers rec 5.5 to 6.0 inch depending on the tire.
Old Apr 25, 2007 | 01:24 PM
Jake88's Avatar
Jake88
WOW! I would never think that you could run a 180 with no Mods? That is awesome. I might have to think about that!
Old Apr 25, 2007 | 09:28 PM
DGlide04's Avatar
DGlide04
What size are you running now? I think the stock width on the '00 models was 140mm, they upped that with the same stock rim in 2004 to 150mm and the best I've seen on a stock rim w/o any modifications or wider rims was a Metzler 160 mm. I'd check with your tire guy or dealer, while a 180 may go on a stock rim, it might be squeezed at the rim and not fit right. Just something to keep in mind before you go out and buy a wider tire. Another possibility is an 18" rim with a low profile tire if you're running a 16" rim now.
Old Apr 26, 2007 | 03:09 PM
Jake88's Avatar
Jake88
I thought about that Dglide04. I guess it's kind of silly when you think about it. I mean we do all this scheming and asking just for 1-3 MM difference? Kind of silly I guess. I'll probably just stick with the stock size for now. Thanks for the input.
Old Apr 26, 2007 | 04:24 PM
2000fxdwg's Avatar
2000fxdwg
ORIGINAL: Maddogs700srx
I have a 2000 wide glide and asked the same question before. I was told that the maximum size is 150 on stock rim / fender / swingarm. Now, someone is sayint 180??? is that right, or just a guess????
Old Apr 26, 2007 | 04:33 PM
Burple_X's Avatar
Burple_X
I have an '07 Lowrider with a 180 on it. Harley dealer installed it before I picked the bike up. I couldn't get anything wider on the bike without fender clearance becoming an issue.
Old Apr 26, 2007 | 05:46 PM
Rebel Ryder's Avatar
Rebel Ryder
I remember this topic from before & believe dgglide04 has it right. don't quote me but Isure my rear metz is 160mm. and it does look much wider thanbefore w/no problems. metz are thinner than flops for sure!
richbob
Jan 19, 2023 08:46 AM
Bongiorni706
Mar 18, 2019 08:14 AM
CycleDrider
Sep 8, 2013 09:40 AM
tmiles
May 2, 2011 02:30 PM
chetter
Apr 25, 2011 05:01 PM
