dyna fork oil
Old Apr 6, 2015 | 07:48 PM
superglidebob's Avatar
superglidebob
Default dyna fork oil
I have a 2005 fxdi with progressive spring and 10 weight bel ray fork oil. forks just seem to soft anybody run 15 weight or heavier oil? thanks in advance
Old Apr 6, 2015 | 08:09 PM
fxrnutt's Avatar
fxrnutt
I'd adjust preload before heavier oil.change you spacer adding a 1/4" at a time . Should get better and the dampening can still work. Heavier oil will slow the compression and rebound and make things harsh. Or burley preload adjusters. ...
Old Apr 6, 2015 | 10:29 PM
Dyna_Bagger85's Avatar
Dyna_Bagger85
I did the drop in lowering kit with Amsoil 10 weight oil and mine is super soft. Talked to the guys at burly and they suggested using the preload adjusters. So that will be my next move
Old Apr 7, 2015 | 01:18 AM
Borisat's Avatar
Borisat
i run caltex 15w in my 2006 wide glide, no brake dive , with no other mods to front end at all
vern58
Oct 10, 2022 12:00 AM
FireFighter200
May 1, 2017 11:59 AM
HeelDragger
Jun 21, 2012 02:11 PM
K9BO
Apr 8, 2012 09:01 PM
Naz_Man
Mar 8, 2009 11:40 AM
