Forward Control Extensions
Old Apr 26, 2007 | 08:36 PM
BlueBob's Avatar
BlueBob
Default RE: Forward Control Extensions
So what is the price of these extentions and the website to get them?
Old Apr 26, 2007 | 11:19 PM
JayFromPa's Avatar
JayFromPa
399.00 and you can order them through your stealer. I got mine for 324.00, but only causeI used my newbie coupon to save 20% on them.
Old Apr 27, 2007 | 01:10 AM
WdGldDave's Avatar
WdGldDave
JP sells a set that gives you 2 inches of extra reach and it costs only $89. The kit includes the extension brackets and a new brake and shifter rod. All parts are chrome plated. I've had mine for about a year with no problems.
Old Apr 27, 2007 | 02:26 AM
makio13's Avatar
makio13
Just take some thick steel plate drill regular holes that match up with frame, then measure out how much further you want to go, make sure you have the same angle and spacing and mirror two more holes at the lenghth you want. plate steel that size can almost always be found free in scrap piles in steel wherehouses. Total cost free.
Old Apr 27, 2007 | 05:10 AM
jmpancoast's Avatar
jmpancoast
Hey Dave:
Your info is exactly what I have been waiting on. You be willing to measure the lengths of your shifter and brake linkages?
Old Apr 27, 2007 | 10:27 AM
WdGldDave's Avatar
WdGldDave
Sure, I'll post the lengths soon. In the mean time check out this thread.
Old Apr 27, 2007 | 11:27 AM
jmpancoast's Avatar
jmpancoast
Thanks Dave. I read through the forward you linked above. I want the measurements of you linkages to see if they will work on the 06. Everything I have seen is listed for use on prior year's model, not the 06 or 07.
Old Apr 27, 2007 | 11:32 AM
Aroberts's Avatar
Aroberts
Here is what I bought $161 to my door. My only concern is I hope they come with everything I need.
http://www.realhog.com/detail.cfm?mo...rward_Controls
Old Apr 27, 2007 | 11:59 AM
jmpancoast's Avatar
jmpancoast
They are listed to work with the 49080-03 controls. I installed the 49080-06 controls. Trying to find out if they will work.
Old Apr 28, 2007 | 05:37 PM
WdGldDave's Avatar
WdGldDave
Ok, here are the measurements:
Shift Linkage - 16 inches
Brake Rod - 24.5 inches
for perspective, here are the measurements of the original parts:
Shift Linkage - 13.8 inches
Brake Rod - 22.5
