brass engine dress up
Old May 3, 2015 | 02:34 AM
on3go's Avatar
on3go
Default brass engine dress up
Does anyone know of any engine bolt kits that are brass bolts? are the alan bolts on push rod tubes and the covers grade 5 or grade 8. Was thinking about replacing them with brass alan bolts but wasn't sure on the strength of them and what they needed to be.
Thanks
Old May 3, 2015 | 03:21 PM
fxdlx's Avatar
fxdlx
Keep in mind, brass tarnishes fast. I would get some stock bolts brass plated.
Don't use brass bolts.
Old May 3, 2015 | 07:24 PM
Davdoodles's Avatar
Davdoodles
re plating the bolts, though real brass plating would tarnish too I think. There are probably brass-look platings you can get that would be ok with the heat and not tarnish... (and possibly even heat resistant brass-look rattle-spray can stuff...)
Also, in boat making, they use silicon bronze bolts etc, which is like brass but much stronger and more corrosion resistant (but more expensive...). Maybe hit up a marine hardware joint.
Old Sep 10, 2015 | 09:48 PM
Chmelion's Avatar
Chmelion
Brass feral or water line compression fits 5/16th fit perfectly over the factory harley allen bolts of the engine and primary. A small dab of super glue holds them on and you can still access the head
Old Sep 10, 2015 | 09:50 PM
ToffeeBrown's Avatar
ToffeeBrown
Looks rad!
Old Sep 10, 2015 | 09:59 PM
Chmelion's Avatar
Chmelion
These have been on for about 2 years.
Old Sep 10, 2015 | 10:45 PM
Chmelion's Avatar
Chmelion
The correct size is 3/8th sorry
Old Sep 10, 2015 | 11:14 PM
fxdlx's Avatar
fxdlx
Looks unique.
Prob look more like they weren't a misapplication of a plumbing ferrule if you filed them slightly so they're flush with the base of the curve on the bolt head, instead of sticking out like they are.
Old Sep 10, 2015 | 11:38 PM
Chmelion's Avatar
Chmelion
Possibly,
They stick out less than a 1/16" past the bolt heads some sanding and the would be flush. The base is sitting up against the factory washers.
I bet if I hadn't said what they were made of, most would be none the wiser.
Old Sep 11, 2015 | 10:08 AM
fxdlx's Avatar
fxdlx
Right, most wouldn't recognize them. I was thinking file them at the base then install them so they taper to the bolt head end. Looks good though, I've always liked brass trim.
