2014 Fxdwg Front fat tire
Wide glides should have come stock w/ a 90/90 instead of that skinny *** tire.
The original idea behind the Wide Glide was a factory build that payed homage to the custom choppers being built back in the day, the wide raked front end, tank flames, and slender 21" wheel is part of that look, I've always thought the Wide Glide is the best looking bike HD has ever built and perhaps I've seen Easy Rider one too many times but I like the old school look. I do plan on adding a solid chrome rear wheel and extending my forks to 3 1/2" over to more accurately reflect the FXDG 'Willie G Disc Glide' limited edition Wide Glide done up in the early 80's, I will swap to the 90/90/21 tire to more completely fill fender space but that's as large as I plan to go, I want to stick with a 21 x 2.15 spoke wheel to follow the Wide Glide tradition.
What do you get when you take the rear suspension and frame of the FLH and combine it with the front end of an XLH? The FX series, Factory Experimental. The WG, like all the FX bikes, is based on the FX Super Glide and it was the wide raked front, flames, and that slender 21" spoke wheel that made it the Wide Glide... tradition, I love it! Now if they'd only put the proper rear fender back on the darn thing!
Djolson, if you do swap to a larger wheel/tire combo be sure and post up images, I'd love to see it and know what your thoughts are on any changes in handling you notice
