200mm on but tight
Old May 12, 2015 | 10:32 PM
cthagreekgod's Avatar
cthagreekgod
Hahaha, sorry, *** shot to follow...
Old May 13, 2015 | 03:15 PM
cthagreekgod
Default *** Shot
As promised. She's all sorted out now.
Old May 13, 2015 | 03:35 PM
GUERRERO's Avatar
GUERRERO
6th Gear
cthagreekgod, don't mean to hijack your thread but I have almost the same set up as yours but with a 180 tire. Can you ride with air dumped all the way? I lowered my fender 1" before I added air ride and fender lays on the tire. thinking about raising my fender back up if its ride able. hate to be stranded one day when the air ride gives out for some reason.
Old May 13, 2015 | 03:53 PM
cthagreekgod
It's tight with the air down, but I think it's survivable. I would't recommend it other than emergency. I think the closest thing to it at that point is the seat nut, as it sits about 3/8 of an inch into the fender. I actually had a leak on my first ride and got home fine, but that was before I fixed my spacing, and the tire rubbed on the left, but I don;t think it hit the fender anywhere.
Old May 13, 2015 | 03:57 PM
jmeiers's Avatar
jmeiers
I have 200, Air ride (Arnotts), and fender lowered (Southeast Custom Cycles) and I can ride with mine fully dumped. However, your spine would be broken after a good pothole.
Old May 13, 2015 | 03:58 PM
GUERRERO's Avatar
GUERRERO
6th Gear
Thanks, are you running a 17" or 18" in the back?
Old May 13, 2015 | 09:35 PM
gartec81's Avatar
gartec81
Great now I gotta do 200 mod. I need to stop reading in this forum.
Old May 14, 2015 | 12:00 AM
Tat2u's Avatar
Tat2u
I would be making sure engine alignment is correct by using the turnbuckle on top engine mount, and then correct any other issues with thinner and or thicker spacers. A lot of measuring needs to be done, my standard wheel was never centred properly but my aftermarket one is now after alot of adjusting here and there
Old May 14, 2015 | 10:27 PM
BigDogIdaho's Avatar
BigDogIdaho
You and me both brother...
Old May 15, 2015 | 05:24 AM
Odin510's Avatar
Odin510
I know the feeling. My buddy out new wheels on his fatboy. I have access to a free 17x6 wheel with tire on it. I'm losing sleep over it! But it seems like more than I want to get into as far as work to get it to fit (based on threads I've read).
