When would I expect to replace [X] ?
Old May 19, 2015 | 12:38 AM
offbeatmammal's Avatar
offbeatmammal
Question When would I expect to replace [X] ?
so, a couple of years ago I got myself a second hand 05 FXDLi. It's got a total of 22k miles on it, of which I've done about 7k.
I'd originally planned to ride it for a couple of years and then trade it for something newer but I'm still enjoying it and so want to keep it ... which means I need to think about what non-frivolous work I should expect to need. Since I've had it servicing has been regular and it's mostly running well but I'm noticing some new rattles and ticks so I'm trying to get some collective wisdom as to what I should look into, and how long things should last before needing someone with a wrench to go wild...
might be an interesting table to put together for the various years and models, but to start it off my selfish interest would love to hear what you think my baby will need....
Oh, and if it matters it was given a Stage 1 (Power Commander, Air and exhaust) before I got it.
- clutch?
- primary drive?
- front forks?
- cam plate/hydraulic lifters?
- front engine mount (I hear they don't last well)
- saddle ( I think the foam is going, or I'm getting fatter!)
- anything else?
Old May 19, 2015 | 01:33 AM
ynots's Avatar
ynots
Find whats ratteling and tighten it down. If mine didnt tic Id think something was wrong with it lol
Old May 19, 2015 | 01:44 AM
Ron750's Avatar
Ron750
I bought an '03 with 2k miles on it on '11. Now, I have 30 k on it. This winter, I had most deficiencies repaired.
These are repairs over the years, all are common repairs.
Quick connect, gas tank replaced. It was leaking. When my Indy replaced it, he also put a new, shorter gas line in. Was known for rubbing against tank, and getting a pinhole.
Then SE Cam chain tensioner upgrade, front engine mount, rebuild front calipers, lower base gasket leak.
Old May 19, 2015 | 07:58 AM
oldbikenut's Avatar
oldbikenut
The usual suspects. Basic maintenance stuff. Brakes, tires, primary chain tension, drive belt condition and tension, motor mounts, engine/frame camber, rubber parts condition, etc.
BTW, this one is a biggie. Those "rattles and ticks" you're hearing could be the cam chain tensioner pads going to pieces and clogging up your oil pump. Check that and address it pronto.
Old May 19, 2015 | 10:36 AM
2500hdon37s's Avatar
2500hdon37s
I would certainly look into the cam chain tensioners with 20K+ miles besides other basic maintenance. Go through it and check everything once, then ride out if all is well.
XTonerman
2014-2024 Touring Models
17
Sep 12, 2020 09:29 AM
Sportster13
Apr 19, 2019 05:22 PM
matt_eglide
Jun 15, 2018 06:55 PM
jpdouglas
Dec 31, 2016 11:06 AM
IronAss
Sep 2, 2010 12:55 PM
