Brake lights work, but running lights do not.
Old May 23, 2015 | 01:10 PM
NuckaMan's Avatar
NuckaMan
Default Brake lights work, but running lights do not.
All was well in the beginning when I installed the Custom Dynamics inserts, all 4 corners worked and light up fantastic. the other day, right before I jumped on the bike for my commute home, I noticed one of the rears did not light up as a running light, but light up when hitting the brakes.
Before I really dig into it, what part of the bike gives the signal to turn on the running light vs. the brake light? This is for a 2015 Street Bob.
Old May 23, 2015 | 01:26 PM
motoboy's Avatar
motoboy
hate to be this guy, but, did you check the bulb?
Old May 23, 2015 | 02:27 PM
NuckaMan's Avatar
NuckaMan
yes. swapped led clusters from other side, same issue.
Old May 23, 2015 | 02:38 PM
motoboy's Avatar
motoboy
have you done any mods that would have had you cut the wires? When I added a detachable sissy, I had to cut. I am sure that my soldering skills are good, but I am always checking my lights and wires for loose connections.
Old May 23, 2015 | 06:45 PM
slyedog's Avatar
slyedog
Running lights are a constant 12v as soon as ign switch turned on. Solid blue wire in rear lamp harness. Wiggle around the contact pad and check again. Sometimes the bulb base gts a poor contact to the socket pad.
load97
Dec 24, 2015 05:54 AM
RustyCage
Dec 27, 2014 04:45 PM
Hammer2284
Jun 12, 2011 03:05 PM
ratWynx
Electrical/Lighting/Alarm
Dec 13, 2010 07:33 AM
cwsharp
Feb 7, 2009 10:44 AM
