Rifle w/ 18" screen buffeting! HELP!
This may seem like a stupid question but before I try the fork baffle...I never had any issues when I didn't have a fairing at all so wouldn't the problem have to be the screen angle / height rather than something below? Wouldn't I have had the same problem without the fairing if it was coming from below? Or is it just the way the air flows with and without a fairing / windshield?
The fairing will mess up the airflow, which would otherwise hit you cleanly in the body. Without the fairing the turbulence is still behind you but you will not notice it. The fairing brings the turbulence in front of your body.
The fairing also creates a vacuum immediately behind the fairing, which sucks the air upwards underneath the fairing and brings it up to your helmet area. If you look at the pic it makes sense.
Now looking at your setup the fairing seems to be quite high. If you look at your tank behind the fairing it seems to form a spoiler, which would even intensify the airflow upwards effect. Your sigpic is small, so I cannot be sure. However after I shifted my fairing down and added the tanklift you can see that the tank is now pretty much tucked behind the fairing.
Now I still have the vacuum behind the fairing, which sucks air upwards, and as said earlier, to get completely rid of the upward airflow around the helmet, the lowers would be good. However, I am already quite happy with my setup as it is now.
Hope this helps.
Thanks again!
Cheers!
Check around the 3rd page of the thread titled "To the Rifle Fairing guys" I think.
Thanks again!
In hindsight, I did change bars from 17" apes to 12" T bars and go from forward to mid controls as well. I'm sure seating/leg position has a good deal to do with it as well.
Here's a link to some pics of it:
https://www.hdforums.com/forum/dyna-...dshield-2.html
