External breather emissions
Old Jun 3, 2015 | 10:23 AM
Ironcleveland's Avatar
Ironcleveland
Originally Posted by Odin510
Was there any reason you didn't put a catch can at the end of the vent tube? I just installed one with a catch can.
I have been thinking about one, just hadn't seen anything small enough. What did you go with?
Old Jun 3, 2015 | 01:30 PM
Odin510's Avatar
Odin510
I did a dk custom AC with the breather system. It came with a little breather filter. I've seen that others have picked up little filters at any auto parts stores.
Old Jun 3, 2015 | 01:48 PM
Warp Factor's Avatar
Warp Factor
Originally Posted by skinman13
This sounds like you are underfilling your oil...which may or may not have something to do with why you are not seeing any drips from the breather tube. Oil level at the 1/2 mark with the engine hot is somewhere pretty close to 8-10 ounces low.
Doesn't matter that much on a dry-sump engine, unless you're burning a lot of oil and need the extra oil to keep it from going dry between checks.
OP, you could run that hose into a beer can if you don't want it dripping. That would be kinda Harley-themed.
Old Jun 3, 2015 | 06:12 PM
Rubline's Avatar
Rubline
I keep my oil level on my Fat Bob half way on the dip stick. Manual says anywhere between the full and add mark, while checking hot oil is fine. I get no misting whatsoever using the DK external breather bolts.
Old Jun 3, 2015 | 08:26 PM
skinman13's Avatar
skinman13
I beg to disagree. Regardless of what you think about dry-sump systems...ALL air cooled engines need the correct oil level to help keep them cool as well as lubrication. Intentionally under servicing your oil level, even by a few ounces, is just inviting a serious engine failure someday...just say'n
Old Jun 3, 2015 | 08:49 PM
LunaticFringe's Avatar
LunaticFringe
this may be good advice, I was in the other boat, keeping mine halfway on the stick with the engine hot. I was doing that to keep my air filter clean. now that I have an external breather & see nothing coming out maybe I should add a bit more oil..
makes sense that more oil should keep the engine cooler.
But on the other hand as long as your oil level is between the marks then you shouldn't have any real problems.
just to note. the external breather also keeps moisture from going back into the intake, not just oil.
Old Jun 3, 2015 | 11:14 PM
racer11's Avatar
racer11
I put a small inline fuel filter for a lawn mower on my hose to use as a catch can. The filter is clear plastic and when the oil crud builds up in it I just reverse flush it out with brake cleaner. My filter is tucked up under my carb and it is not easily in view. 00 fxdwg model.
Old Jun 4, 2015 | 02:51 AM
tfalcon's Avatar
tfalcon
I used a chrome breather filter I got at Advance Auto for $9.
So what good does that do? Doesn't the oil just collect inside the filter and eventually drip out?
I've been meaning to swap out my intake for a dk one with the external breathers, I run the bike pretty hard and it doesn't take much for the air filter to start dripping oil. I have a maintenance plan with the dealer so they do all the oil changes so it's right under the full line when hot. I was gonna get this http://www.tt-motorcycles.com/catalo...VERFLOW_CA.htm and see if I can rig it up to use as a catch can.
Old Jun 4, 2015 | 04:46 AM
Warp Factor
Running the oil level at the half-way mark is not "under-servicing", or incorrect. On a dry sump setup, the oil system will function exactly the same at different reservoir levels, as long as the oil pickup stays submerged. The only difference is that when the oil level is high in the reservoir on our bikes, more will be splashed into the reservoir vent tube, and be blown out the breathers.
On an air-cooled engine which relies on splash lubrication (rather than being pressure-fed), you'd be right that oil level is much more critical. You'd also be right that if we had a completely separate oil tank (like on a softail), when the oil level is higher in the tank, there might be slightly more heat transfer from the oil, to the walls of the tank, and then to the air. But our Dyna oil tanks are essentially one-piece with the engine/transmission assembly, so added cooling from running a higher oil level would be practically non-existent.
Old Jun 4, 2015 | 08:25 AM
WVDevil's Avatar
WVDevil
I just wipe around the breather and back side of air cleaner occasionally.
