could use some input 2005 vs 2009 Low Rider
Old Jun 16, 2015 | 11:11 PM
Balrog's Avatar
Balrog
1st Gear
Default could use some input 2005 vs 2009 Low Rider
Based on my budget, I've narrowed it down to a couple bikes. One is a low mileage 2005, and the other is a 2009 that appears to be more stock, also with low miles. (Both are pretty close to 5k on em). The price is a few hundred difference. I like the color, and head start on mods that the 2005 has, but the 2009 may hold value longer?
I know the 2005 has stage 1 carb etc, but not sure about the 2009. Carb or EFI. Was there any significant differences between the models in those years? I'm not that familiar with the Dynas in general, and don't know any specifics on the Low Riders.
Old Jun 16, 2015 | 11:15 PM
jkloeker's Avatar
jkloeker
I would go 09 all day, every day. Bigger motor, extra gear in the tranny, and used parts readily available.
Old Jun 16, 2015 | 11:17 PM
Ironcleveland's Avatar
Ironcleveland
Go with the 2009. Fuel injection and 96 c.i. motor. It will cost more than a few hundred to make that 88 bigger, although there are guys that get a lot out of those motors.
Old Jun 16, 2015 | 11:32 PM
ynots's Avatar
ynots
For me that would be a no brainer... the 2009 for the above reasons
Old Jun 16, 2015 | 11:36 PM
Balrog's Avatar
Balrog
1st Gear
That was fast, and a pretty clear message too. Thank you all for the insight and advice.
Old Jun 17, 2015 | 12:02 AM
dirtdreamer50's Avatar
dirtdreamer50
Sounds like you have decided. As an addendum, I agree with the 09, especially if the prices are as close as mentioned. No choke/cold start problems with FI. Four fewer years deterioration of rubber goods and electronic/wiring, etc. Higher value, down the road. The LOW is very similar to my FXDC, and it is the best Harley I have owned to date, well, except maybe for the XR1200.
Good luck with your purchase, and post a pic or two. tomp
Old Jun 17, 2015 | 07:16 AM
Mr Bentwrench's Avatar
Mr Bentwrench
My '07 FXDL has the idiot lights intergral to the pull back risers that can be problematic for changing out risers and bars.
Old Jun 17, 2015 | 08:43 AM
dwagar's Avatar
dwagar
Wasn't the chassis change in '06? That'd be another vote for the '09.
Old Jun 17, 2015 | 10:44 PM
Balrog's Avatar
Balrog
1st Gear
OK, pulled the trigger on the 09. Went and looked at it today, and put a deposit on it. Pick it up Saturday morning. 4120 miles on it. Now, I've got to find some louder exhaust and start changing things around a bit.
Daughter had to make sure it comfortable for two up. She approves.
Old Jun 17, 2015 | 11:42 PM
dirtdreamer50
Exhaust looks stock. So many different exhaust from which to choose. Enjoy the new scoot. tp
