2011 Wide Glide Starts Hard
Old Jul 7, 2015 | 02:22 PM
hitman1267's Avatar
hitman1267
Default 2011 Wide Glide Starts Hard
Every once in a while when starting the bike she'll take quite a bit to crank. If I hold the ignition button too long I will hear a loud grinding noise. So I let it crank for a few seconds if she doesn't crank I push it a second time and she starts right away. She's got 11k miles on her. Thanks for the help!
Old Jul 9, 2015 | 03:14 PM
Redbeard's Avatar
Redbeard
The grinding noise could be a problem with the starter. As for hard starting, the simplest thing to check is the connections at the battery terminals. A while back, one of mine came loose and was causing sluggish cranking.
Old Jul 10, 2015 | 08:50 AM
hitman1267's Avatar
hitman1267
Thanks bro ill check it out!
Old Jul 10, 2015 | 09:46 PM
fireman64's Avatar
fireman64
When starting mine, if it doesn't fire off I let off starter and hit again and always fires off..
Old Jul 17, 2015 | 07:27 AM
hitman1267's Avatar
hitman1267
Yea same here, I thought maybe it'd be a tuning issue as well.
Old Jul 17, 2015 | 08:43 AM
HD Bobber's Avatar
HD Bobber
...........might be time for a new battery?
Old Dec 23, 2015 | 02:03 PM
jaxdwg's Avatar
jaxdwg
That was my first thought too. The starter draws a bunch of electricity and drops voltage under load. If you have an old or weak battery it has a tendency to give the coil less voltage and therefore a weaker spark to the plugs, which in turn may not be firing as hot as necessary for that quick start. When these things occur on my equipment I head to the battery first before looking elsewhere.
TravisD27
Apr 9, 2018 02:05 PM
Buckinfitch
Engine Mechanical Topics
Jun 23, 2017 10:07 AM
jbkrab
Jun 9, 2015 06:35 AM
Tjakubik
Electrical/Lighting/Alarm
May 31, 2015 02:57 PM
Skippy97
Jan 8, 2013 03:53 AM
