Inverted forks
Old Jul 11, 2015 | 02:47 PM
apetterez's Avatar
apetterez
Default Inverted forks
What is the purpose of inverted forks? The the 39mm sportster xr forks? I'm sure it is for performance but what does it do differently to make them perform better
Old Jul 11, 2015 | 04:00 PM
sullspots's Avatar
sullspots
Unsprung weight?
Old Jul 11, 2015 | 04:56 PM
Pokey151's Avatar
Pokey151
For off road bikes I know they switched to inverted for more rigidity. Conventional fork have a lot of flex, for cross country bikes they tend to keep conventional.
More important is proper spring weight and valving
Old Jul 11, 2015 | 07:38 PM
union53's Avatar
union53
That pretty much nails it. Inverted forks have less flex then conventional forks. Makes the geometry a bit more predictable which results in a better handling bike. Most manufacturers have made the switch to them for most of their models except for the lower end machines, Harley hasn't quiet caught up to the 1990s yet.
Old Jul 12, 2015 | 12:40 AM
LunaticFringe's Avatar
LunaticFringe
sounds like there is very little difference, Harley is making what now? 43mm forks? that should be plenty stiff, no need for inverted forks.
my front end does vibrate & flex a bit when I hit very hard bumps, but fork brace helped a lot.
seems to me they would leak easier & quicker, & harder/ more expensive for maintenance.
if you want to do something that makes a real difference get a fork brace, for the money they are a must have in my book.
Justin Lynn
May 14, 2017 08:59 AM
Big_Dave88
Air Suspensions
Feb 25, 2017 06:11 AM
goats
Nov 14, 2011 04:14 AM
bucket13
May 8, 2010 07:36 AM
JosephGarcia
Oct 27, 2007 08:17 PM
